Radio Security Code
Submitted: Sunday, Jun 03, 2007 at 08:39
ThreadID: 46200 Views:19609 Replies:8 FollowUps:2
Hi All,
After gaining great value from this site I've finally done the right thing and joined up.
I have a Toyota Starlet that I use for commuting. The radio/cassette has a problem which will entail removing, but I have been given no security code so as soon as I disconnect power it will be stuffed.
Is there any way the security code can be reset without knowing the original.
Or is it a matter of taking it back to Toyota and paying through the nose?
Thanks in advance.
Greg..
Reply By: Member - JohnR (Vic)&Moses - Sunday, Jun 03, 2007 at 08:45
Greg, Toyota as part of their normal service should be able to provide that to you then again you say they pay through the nose with them. They should be able to give it to you.
AnswerID: 244288
Follow Up By: Member - JohnR (Vic)&Moses - Sunday, Jun 03, 2007 at 08:53
Its worth arguing the point they should give you the security code for your own radio - especially if there are others in the shop, but just plan what you will say and not much more.
FollowupID: 505262
Reply By: Garbutt - Sunday, Jun 03, 2007 at 10:25
I had similat problem in a Ford, the local dealer found out the code for me no probs and no charge, can't see why Toyota should be any different.
GB
AnswerID: 244305
Reply By: Steve from Top End Explorer Tours - Sunday, Jun 03, 2007 at 10:46
They once used the last 4 digits of the chassis #
Try that Steve.
AnswerID: 244312
Reply By: Member - joc45 (WA) - Sunday, Jun 03, 2007 at 10:49
Had an interesting problem a coupe of years ago; I had fitted a 2-way radio to a rented 4wd, and had to disconnect the battery to connect the wiring. Naturally, the radio stopped working, so I rang the hire mob to get the pin code, which they obliged. The code wouldn't work. After much frustration, I checked the hire car paperwork to see if that would shed any light on the matter, when it became apparent that they had given me the wrong car! Another phone call, was told not to worry, keep that car, and I got the correct pin code.
Gerry
AnswerID: 244313
Reply By: Member - extfilm (NSW) - Sunday, Jun 03, 2007 at 11:21
Ecery time I have disconnected the battery to rewire some of the accsessories I simply rang the dealership, told them my number plate number and they gave me the code instantly. No Charge.
AnswerID: 244327
Reply By: Mikee5 (QLD) - Sunday, Jun 03, 2007 at 13:59
I have a Toyota Landcruiser 100 series. Before I disconnected the battery for the first time I asked Toyota for the radio cassette security code. I was told (for free!) the code was not set up unless it was requested. I took them at their word and disconnected the battery. On reconnection it all worked without any code.
AnswerID: 244354
Reply By: donks1 - Sunday, Jun 03, 2007 at 18:06
toyota radio codes are set by each dealer. each car that dealer sells has the same code. if you are the origional owner, call the dealer you bought it from. otherwise you need to find the selling dealer
donks
AnswerID: 244416
Reply By: Member - Stephen M (NSW) - Sunday, Jun 03, 2007 at 19:44
Normally the last three digits of your chassis no. If you have any problems contact me through members and I will give you my phone number and give me a ring will put you onto my mate who should get it for you with in 5 mins. Regards Steve M
AnswerID: 244465
Follow Up By: obee - Sunday, Jun 03, 2007 at 20:17
I never understood why I got a cassett/radio with my hilux in 2001 cos the cassettes about obsolete then. I ditched it and got a cd/mp3 player and now they bring out usb docks! And soon it will be digital radio so I better wait for that one and then it probably be sattelite.
Owen
FollowupID: 505440
