Tightening Landcruiser 100 LSD
Submitted: Saturday, Jun 09, 2007 at 21:55
ThreadID: 46467 Views:6294 Replies:4 FollowUps:5
A year or two ago 4WD Monthly did an article on the Landcruiser LSD and it mentioned how much shim to add and/or what torque is required to 'slip' once.
I went though the pile of magazines and found everything but the article.
Has anyone got, seen, remember the specs or even played around with different settings. No point reinventing the wheel.
Reply By: Member - Troopytrek - Sunday, Jun 10, 2007 at 04:50
G'Day anleky, On our previous troopcarrier we had limited slip front and rear. As for actual torque ratings or anything I can't really help you. The shim sizes range from A to M. In our front diff we had M in our rear diff we had K [to enable a bit more slippage on general driving] shimming the diffs did make a great difference and with our old troopy we did some pretty serious tracks. But our new troopy has factory front and rear lockers and they are amazing. hope this helps a bit. Cheers Troopytrek.
AnswerID: 245818
Follow Up By: anleky - Sunday, Jun 10, 2007 at 09:27
Thanx Troopytrek,
Will pull the diff out today measure the shim then go and see Mr. toyota to decifer the letter codes to see what I have and need.
Did you notice any understeer whith that set up?
FollowupID: 506821
Reply By: Member - Davoe (Nullagine) - Sunday, Jun 10, 2007 at 07:19
dunno if you are doing it yourself but if you are going to reomove the diff and muck about with it i would compare the price to a locker as it will be far more effective
AnswerID: 245819
Follow Up By: anleky - Sunday, Jun 10, 2007 at 08:37
I will do it myself.
I can't justify the price for the airlockers.
FollowupID: 506812
Follow Up By: Footloose - Sunday, Jun 10, 2007 at 09:08
Do you really need airlockers ? What about other ways to go ? Several years ago I enquired about my 80 series rear diff. To have it rebuilt was around $4-500. To buy a slip diff was around $650 at the time.
FollowupID: 506819
Reply By: Hillbilly123 - Sunday, Jun 10, 2007 at 10:52
If this is what u r looking for its in Issue 92 May 2006 on page 169
Is actualy done on a miss a bitsi but may be what u want
AnswerID: 245856
Follow Up By: anleky - Sunday, Jun 10, 2007 at 21:09
Went through all of the Issues, missing 92, thats probably why I can't find it.
If it was for a not much help anyway.
Thankyou for having a look.
FollowupID: 506922
Follow Up By: Hillbilly123 - Sunday, Jun 10, 2007 at 22:37
Perhaps if U email to the mag they can help you as I have seen letters to the editor requesting location of articles. Regrettfully they dont have them indexed but apparently are looking at doing so
FollowupID: 506938
Reply By: anleky - Wednesday, Jun 13, 2007 at 14:30
Well....
Checked out what shims were avalable and only 4 options A,B,C,D.
Measured the wear as per the W/Shop manual and went alittle tighter.
Put the diff back in and went to test it in a sand hill and Bang the front diff Sh1t it self.
Pulled the front diff out, It had striped one spider and a bit of the spider went into the crown wheel and pinion and broke a tooth on that.
Why Toyota put a small 2 spider gear in the front and a 4 in the rear has got me stuffed?
So I will have to eat my words 'that i can't justify a locker.' At least any Locker or LSD has 4 spiders.
Toyota locker on the way.
AnswerID: 246575
