Laptop question
Submitted: Monday, Jun 11, 2007 at 11:50
ThreadID: 46520 Views:2299 Replies:8 FollowUps:3
Having purchased a laptop to use on my trip up north I have made some inquiries about connecting to the internet while i'm away but have not got a clear answer.My question is what do I have to do to configure the laptop so I can just plug in from a friends house or internet cafe or any other phone line and access the net.Telstra told me I should buy some disc that Iload or use a card .I am a bit confused as surely with all the laptops around it can't be that hard to to hook up to the internet.By the way it works fine on my broadband cable connection at home, but would not connect when I tried it on a friends phone line.
Reply By: DIO - Monday, Jun 11, 2007 at 12:50
Make sure that your laptop has a modem and relevant software installed. Connect to phone point with appropriate cable, then you will probably have to re-configure your browser (IE or whatever) from never Dial a Connection to Always Dial my Default Connection. You will need to set up the dial number and other connection protocols. Most importantly ensure that your ISP provides you with a local number (based on regions) or a 1300 otherwise you will have to dial STD and that could become costly. Best and cheapest advice (realistically sepaking if you are not real sure and confident in what you are trying to do) - use Public Lbraries or Internet Cafes.
AnswerID: 246053
Reply By: disco1942 - Monday, Jun 11, 2007 at 12:51
Your computer will most likely have a built in phone line modem. Set this up so that you dial into your ISP (internet supplier.) Many ISPs have this option for when your broadband is out of service - it should be an 019 number. If you can dial in from home on a 019 number then you can dial up from anywhere in Oz for the cost of a local call, anywhere you can get access to a phone line. Check with your ISP.
If you have a network connector on your machine then most cafes will hook you up to a cable for the same cost as using one of their machines.
AnswerID: 246055
Follow Up By: The Explorer - Monday, Jun 11, 2007 at 13:32
Yes - my ISP (iinet) gave me a phone number to ring when on the road. Plug laptop into phone line and dial away. Just use the "New Connection Wizard" in Network connections to create a shortcut for you desktop. No need to change any settings etc, should all be straight forward.
A number of caravan parks/hotels/(cafes?) now have wifi internet avialable at a cost - though based on my experience it is normally only economical if you are staying for week or more eg $16 for 24hrs or 100mb download limit that must be used within a certain period of time. Occasionally you may jag an unsecured network and get on internet for free. A drive around the suburbs/towns reveals many available networks. This may of course be breaching some rules but if your desperate it can be handy (not that I have ever done it - just heard about it:)
FollowupID: 506990
Reply By: Graham & Ann - Monday, Jun 11, 2007 at 13:00
How often/much would you use the interent on the laptop??
If you only want to use it on the road for a few weeks holiday you could just go to internet cafes and hookinto thier system for around $4 hr or if you have a Next g mobile phone consider a Telstra casual data pack.......
Site Link
We use bigpond but thats 12mth contract and you have to buy the modem
Site Link
or you could go to vodafone if your not travelling outbac or off the main highways
Site Link
AnswerID: 246057
Reply By: Member - Doug T (W.A) - Monday, Jun 11, 2007 at 14:42
Get yourself a Bigpond Wireless account on Next G . then you won't need to hook it to slow old phone lines that will need you to include the number called from ,
Site Link
AnswerID: 246075
Reply By: Philip A - Monday, Jun 11, 2007 at 16:21
I researched this and concluded that since I had an ADSL2 contract at home and I only wanted mobile internet for about 8 weeks, it was not worth the $300 and 2 year contract for a USB next G modem .
I bought a Telstra 252 next G phone on a 2year contract for $30 per month and $49 for a carkit. the phone comes with "join me" software which converts it to a Next G modem for the laptop.
You can then buy data packs from Telstra when you need them, and they also have a special deal of 37.5 megs for $8 for the first 2 months.
The packs are then $59 for 200megs per month up to $ 179 for 2000megs.
I use dit quite a bit when we had no power for the last few days, and found it quick and accurate.
You can get a reading of how many megs are used at any time on the phone also, and it also appears on teh laptop in the Join me software.
Prefer this to Macdonalds as you cannot use your mail program at Maccas, only webmail.
Regards Philip A
AnswerID: 246094
Follow Up By: Andrew from Vivid Adventures - Monday, Jun 11, 2007 at 20:39
I'm doing this too. Works well with the Samsung A701 phone which plugs nicely into the laptop and delivers.
FollowupID: 507054
Reply By: Member - Phil G (SA) - Monday, Jun 11, 2007 at 18:58
I just drive around and break into someone's unsecured wireless network :-)))
AnswerID: 246128
Follow Up By: Member - lyndon K (SA) - Tuesday, Jun 12, 2007 at 23:02
Yep, had a great time when we moved into our new unit, free adsl2. Very kind of them :)
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
FollowupID: 507307
Reply By: Kumunara (NT) - Monday, Jun 11, 2007 at 20:28
The Rambler
You can connect using dial-up from any phone line.
To connect to broadband the phone line has to be configured. You cannot connect through any phone line.
Many ISPs have an option where if you have a broadband account you can use dial-up when away from home.
Tjilpi
AnswerID: 246166
Reply By: Richard Kovac - Monday, Jun 11, 2007 at 21:26
Rambler
My acer travel mate 280 has a built in modem, just a plain old modem, ie just plug in phone line. I never got rid of the old dial up plain I had with Bigpond $20.00 per month unlimited .
so where ever there is a phone line I can plug into it and dial the secret number and the only cost is $20.00 per month, wise old saying never through out something just because it's old ...LOL
Richard
AnswerID: 246194
