Stud Pattern of Challengers
Submitted: Tuesday, Jun 12, 2007 at 20:54
ThreadID: 46593 Views:8879 Replies:4 FollowUps:2
G'Day
I own a 2001 Mitsubishi Challenger. Could anyone tell me if it shares it's wheel stud pattern with any other 4 WD, as I am looking to put different rims on my Challenger. Thanks, Rob
Reply By: Member - Andy C (WA) - Tuesday, Jun 12, 2007 at 21:49
Rob - try the web for rims by Speedy (www.speedywheels.com.au) or ROH (www.rohwheels.com.au).
They have different tables from memory that could lead you in the right direction.
Or maybe some Mits 4wd club!
Andy
AnswerID: 246449
Reply By: pickle - Tuesday, Jun 12, 2007 at 22:37
Challengers share the same stud pattern as most other 4wds. Only problem you could have is offset of the rims. I have Pajero Nl rims on mine currently and have had Sunraysia rims with a negative 13 offset on as well with no problems.
AnswerID: 246467
Reply By: Member - Scoof (SA) - Tuesday, Jun 12, 2007 at 22:58
Hi rbarnes,
I reckon all 6 stud rims are the same stud pattern but as someone else said the offset is the only problem.
Just try them on and make sure it misses the brakes and steering components.
My camper trailer rims fit my pajero, and my 3rd spare is a Hilux rim we tried a Ford (Mazda ) rim and it fowled on the disc brake calliper.
Cheers Scoof. :-)
AnswerID: 246473
Reply By: traveller2 - Wednesday, Jun 13, 2007 at 08:18
Aren't Challengers earlier model Pajero's with a different body?
If so then Pajero rims will fit. Any 6 stud rim, Toyota, Nissan, Mitsi should fit but check that the off set is correct and clears brake and suspension components on all 4 corners
AnswerID: 246500
Follow Up By: Member - MrBitchi (QLD) - Wednesday, Jun 13, 2007 at 08:42
That's like saying a Prado is an early model 'Cruiser with a different body ;-p
Not so. They do share some mechanicals though.
FollowupID: 507330
Follow Up By: Blaze - Wednesday, Jun 13, 2007 at 09:34
"That's like saying a Prado is an early model 'Cruiser with a different body"
Well isn't it? ;-) LOL
FollowupID: 507335
