Troopy wheel offset
Submitted: Wednesday, Jun 13, 2007 at 23:53
ThreadID: 46639 Views:6667 Replies:5 FollowUps:3
Hey guys,
I bought two new sunraysias for my troopy.
The wheels on the car are 16 x 7 and I now have two 16 x 8 spares.
I fitted a new 16 x 8 to the left hand front and it cleared the calliper by about 0.5mm.
I fitted the other new 16 x 8 to the right hand front and it rubs on the calliper.
All wheels, old and new, 7" and 8" are the same offset.
I went to the tyre shop and they can't figure it out.
The same wheel touches the calliper on one side but not the other.
The only solution so far is to grind about 1mm off the calliper!!!
Any suggestions?
Cheers, Jack
Reply By: Member - Nev S (QLD) - Thursday, Jun 14, 2007 at 07:36
Hi Jack
Ihad the same problem when I fited mags to my GQ. Solved it by fitting spacers Ipurchased from Repco. Hope this helps
Regards Nev S
AnswerID: 246699
Follow Up By: traveller2 - Thursday, Jun 14, 2007 at 08:07
In NSW and I think all of Oz wheel spacers are illegal, QLD who knows!
FollowupID: 507516
Reply By: Member - Phil G (SA) - Thursday, Jun 14, 2007 at 09:05
I'll assume that you have a 78series 5stud troopy.
The 16x7 and 16x8 should have different offset, and the same backspacing.
Can you measure the backspacing of both size wheels for me. It is the distance from the mounting surface to the inside lip of the wheel.
I've got 16x7 Sunraysias, and they have about 105mm of backspacing.
AnswerID: 246716
Follow Up By: Member - Phil G (SA) - Thursday, Jun 14, 2007 at 21:26
I'm guessing your 16x8 have the IFS offset, which is why they are almost touching the caliper. Put some tyres on them, and I think you'll be wiping out the ball joint rubbers on the front, and rubbing against the leaf springs on the back.
FollowupID: 507700
Reply By: Member -Signman - Thursday, Jun 14, 2007 at 09:23
No probs. grinding a couple of mm off the caliper. There's plenty of 'meat' there!!
AnswerID: 246721
Reply By: Member - Tour Boy- Thursday, Jun 14, 2007 at 14:44
Hi It hasn't had a different caliper put on one side at some stage has it?. I once used a 60 series in a 75 that fitted but was probably slightly different.
TB
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 246785
Reply By: CapeYorkTroopy - Friday, Jun 15, 2007 at 09:51
Phil, I am not sure exactly what measurement you are after, could you describe it in a bit more detail please.
I have the 75 series 6 stud troopy.
I have measured all around the caliper and mounting surface (not including the wheel) and both front sides are identical.
All wheels are zero offset.
The tyres dont rub, just the wheel touching the calliper.
Cheers, Jack
AnswerID: 247005
Follow Up By: Member - Phil G (SA) - Saturday, Jun 16, 2007 at 12:12
Jack,
The above diagram shows what backspace is. If a wheel has no tyre on it, you simmply lay it down on concrete, and heasure the distance. If you have a tyer on it, lay a piece of string across the inside of the rim and measure.
Backspace needs to be the same on a particular vehicle (to prevent fouling). Offset will differ with the width of the rim - so the offset on a split rim, 7 inch and 8 inch rim will have different numbers for your troopie.
I'm guessing that the 16x8 rims have too much backspacing - I reckon they may be the ones for the 80series and Prado. The backspacing for your 75series should be about 65-80mm.
FollowupID: 508059
