3rd Battery for the ute
Submitted: Saturday, Jun 16, 2007 at 18:20
ThreadID: 46743 Views:2052 Replies:5 FollowUps:9
Hi all,
I have been given a 70ah battery but will not be picking it up until mid July.
How will I prepare to install it before i pick it up as when I do pick it up I will be starting my next adventure.
Do I just get it ready to set it up parralell or is there another way?
Reply By: Kev M (NSW) - Saturday, Jun 16, 2007 at 18:44
Ask Roachie,
he's had fun installing his 3rd battery in the Chevnissan LOL :)
Kev
Russell Coight:
AnswerID: 247271
Follow Up By: Member - Roachie (SA) - Saturday, Jun 16, 2007 at 19:04
Thanks Kev, ;-))
Yes, I have just fitted a 3rd batt to the Chevnissan; just to assist the main batt with starting duties.
It depends a bit on where you want to/can fit the battery and what use you intend for it.
I'm assuming that you won't have space under the bonnet for a 3rd battery, so you'll need to find a place to mount it in or under the tray. Preferrably under I suppose. I would be making up (or buying) a suitable tray or box to house the battery. I would suggest you could run some HEAVY (I used "OO" cable) where you need to, making sure you have enough additional insulation to protect it from being worn through anywhere.
The actual connection/s will depend on what you're using it for.
1). If it's to assist the starter batt, (like mine) then I didn't use any gizmos (sorry for the very technical term) in between the 2 batteries.....IE: no solenoid, fuse, circuit breaker etc. I made sure I placed a sign on both ends, stating " CAUTION: CABLE ALWAYS LIVE". This is because even if a mechanic or someone should happen to remove the cable from the starter battery to do some electrical work etc, the cable is still alive due to the power coming through from the 3rd battery.
2). If you want to use the 3rd battery to assist your existing 2nd battery to run accessories etc, then a similar system to above could be used, but you can safely use a circuit breaker etc or even employ a manual or smart solenoid etc. However, I wouldn't bother......just a circuit breaker at both ends of the cable should be okay.
Hope this makes some sense......;-))
Roachie
FollowupID: 508122
Follow Up By: Kev M (NSW) - Saturday, Jun 16, 2007 at 19:12
I thought you'd like an introduction :))
Kev
Russell Coight:
FollowupID: 508125
Follow Up By: Member - extfilm (NSW) - Sunday, Jun 17, 2007 at 19:44
Thanks Roachie,
When u say circuit breaker what do you mean? a relay?
FollowupID: 508338
Follow Up By: Member - Roachie (SA) - Monday, Jun 18, 2007 at 08:15
No mate. A circuit breaker (sometimes called a fusible link too) is a relatively small "box" (about 30mm x 10mm x 10mm). It has 2 bolts protruding out the top and on the bottom there is a mounting plate with 2 holes. The 2 bolts on top are marked "IN" and "OUT"......the "OUT" bolt is a bit longer than the "IN" one and they appear to be made of different metals (one is copper and the other is steel; or that's how they 'appear'). I just tried to find (via a Google search) a photo of one, but couldn't see one anywhere.
Anyway, your local auto electrician would have them in stock in various capacities.
Hope this helps.
FollowupID: 508427
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Jun 16, 2007 at 19:06
Hi extfilm
Where will you be mounting the battery and what isolation system do you have at the moment ?
Will you need to be able to crank off it or is it purely for fridge and lights ?
Derek.
AnswerID: 247276
Follow Up By: Member - extfilm (NSW) - Sunday, Jun 17, 2007 at 03:00
Hi Derek,
I will be mounting the battery just behind the driver's seat on the tray. Not underneath. It will be used solely to power fridge and lights.
I can not remember what the isolation system is but it is dealer fitted.
Can I simply wire it in Paralell?
FollowupID: 508203
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Jun 17, 2007 at 11:01
Yes, use heavy wire, at least 8 B&S and parallel them.
Fit a large fuse or circuit breaker at each end of the cable. (50 amps will do).
I would use auto reset breakers if you have a winch fitted or sometimes try cranking off the no. 1 aux battery.
FollowupID: 508231
Follow Up By: Member - extfilm (NSW) - Sunday, Jun 17, 2007 at 23:45
Thanks derek,
I will do a few measurements and put in an order shortly...... In the meantime I will get the dimensions of the battery.
It is 2 years old and I believe it is an agm but wil find out anyway.
cheers peter
FollowupID: 508392
Reply By: PatNav - Saturday, Jun 16, 2007 at 21:20
Extfilm
hi, 1st have you got the measurments of battery ,if so maybe prepare a cradle for it mounted under the tray ,if its just for accesories just run it through a relay set up so it only charges when car is running thats the easiest way and cost effective ,my old navara has had the second battery done that way for about 8 yrs now and no probs on that had to replace battery but you get that .good for running acc(lights,fridge,cordless drill wifes toys oops !!!!!!!\cheers pat
still love your photos too
keep it up
AnswerID: 247303
Follow Up By: Member - extfilm (NSW) - Sunday, Jun 17, 2007 at 03:09
Hey Pat,
Thanks, you can expect some more pictures in september after my next adventure...... Am hoping this one will be at least 6 to 8 weeks.
In the meantime I have just put up a selection of pics for a portfolio for a job www.extremefilm.com.au/portfolio Fingers crossed I get it. :)
Unfortuanetly I have not got the measurments as yet but I plan to mount it on the tray just behind the drivers seat. Will do something very simple and will mount it on the road as I will be taking a drill and grinder with me.
What I need to know is do I need any other Gizmos (As Roachie puts it) or can I just simply run straight to the 2nd battery in Paralell? Just remembering I am not keen on keeping this machine.
FollowupID: 508204
Reply By: Member - Brian H (QLD) - Sunday, Jun 17, 2007 at 08:29
Nice photo's extfilm ............... if i can get half as good i'll be happy :)
Brian
AnswerID: 247373
Reply By: warfer69 - Sunday, Jun 17, 2007 at 23:06
Hi Derek
Ive noticed since i have been on this forum,whenever their is a battery problem your quick to answer it in a kind way and good on ya mate !
AnswerID: 247582
Follow Up By: Derek from Affordable Batteries & Radiators - Monday, Jun 18, 2007 at 07:31
Thanks warfer69
Your positive feedback is much appreciated.
Derek.
FollowupID: 508418
