Tyre Pressure "But I am new to all this!!!!!"
Submitted: Saturday, Jun 16, 2007 at 18:25
4be
I again just wondering what would be the best tyre pressure (everyday road use) to run in by BF Goodrich All Terrains they are fitted to a single cab Hilux which is my daily commuting vehicle. Thanks again.
Reply By: Axel [ the real one ] - Saturday, Jun 16, 2007 at 18:33
4be [used to be a radio station with that call
sign] have a look in the search function , just type in 4psi rule and you will get to spend the next day or two reading up on tire pressures .
247266
Follow Up By: 4be - Saturday, Jun 16, 2007 at 18:37
Thanks for that am onto it now.
508117
Reply By: obee - Saturday, Jun 16, 2007 at 18:40
toyota have recommended psi on the door frame when you open the door. I dont believe it myself. The tyre people should have recommended then they cant get out of probs re under inflation. I have found two diffent brands wore differintly at same pressure and had to adjust to get the tyres to wear evenly. What ever you decide keep checking the wear pattern at least every 5K and more often if you remember.
A bump over the kerb or simillar can be enough to put the alignement out I have been told so dont rely on anything less than your eyesight.
Owen
247269
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Jun 16, 2007 at 19:28
Hi 4be
I have the BFG 285's on the LC100 and have found them to run best at 240 kpa. Any less they get 'loose' on the road. Your rig is lighter so I would say 220-230 kpa. Don't run them too low as they will wear down on the edges.
Derek.
247283
Follow Up By: Bonz (Vic) - Sunday, Jun 17, 2007 at 22:00
How many is that in real pressures?
508378
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Jun 17, 2007 at 22:40
Hi Bonz
32 psi to 34 psi for everyday unloaded commuting as stated. Increase the rears if you load it up.
I found a great converter...
KPA to PSI
Here is a spec sheet on some AT's. I am not sure what size you have.
BFG's
Here is a UK chart. I can't find the Hilux local specs. Pressure Chart
Derek.
508386
Reply By: Crackles - Saturday, Jun 16, 2007 at 20:27
Depends on the size of your tyres & how much weight you carry. BFG don't recommend set preasures rather they have a measurement called the "Static Loaded Radius". For example a 225/75R16/D BFG Mud terrain has a S.L.R. of 13.6" measured from the middle of the wheel to the ground. It doesn't matter what load you carry or on what vehicle they are fitted to, the tyre is pumped up to that measurement. This ensures the tyre is at it's optimum shape for road holding, wear, braking & grip. Sorry I don't have the Data Sheet for the All terrains only Mud Terrains.
Cheers Craig...............
247296
Follow Up By: PatNav - Saturday, Jun 16, 2007 at 22:53
hI 4BE
I fun
mine with 60psi of top nick heylium i think thats how you spell it LOL i was of that day haha,the stuff u fill balloons with,it cut my fuel bill in half fely like i was flyin to work but took longer to get home in was down
hill LOL,
No really check the side of tyre and stick to the spec on that ,it your best bet
Good luck with it no doubt every1 runs different psi
cheers Pat
508185
Reply By: Wayne-o (Pilbara WA) - Sunday, Jun 17, 2007 at 14:05
i run 45 psi everyday and find it best.
247439
