Rodeo knocking noise
Submitted: Sunday, Jun 17, 2007 at 08:18
Member - David L (NSW)
G'day All,
Can anyone out there help with a knocking noise in my 93 4x4 rodeo, eminating from underneath, mid to rear region, maybe more LH side??
It sounded like shock absorber rubbers, I replaced these, no joy. Then I thought it sounded like loose jack under rear
seat but it is secure. Thought it could be exhaust but it seems secure also. Thats the sort of noise it sounds like. Mainly does it over small bumps at low to mid speed and occasionally when backing off.
Any help appreciated.
Reply By: Stu050 - Sunday, Jun 17, 2007 at 09:31
Dave,
Check your leaf spring bushes. Wear on these could be causing a metal to metal contact.
247383
Follow Up By: Member - David L (NSW) - Sunday, Jun 17, 2007 at 11:35
Stu050,
Thanks mate, I will check these in the next day or so. Do you know if they are rubber or polyurethane??
508236
Follow Up By: Stu050 - Sunday, Jun 17, 2007 at 11:37
Dave,
Probably used to be rubber.
Stu
508238
Follow Up By: Member - David L (NSW) - Sunday, Jun 17, 2007 at 11:40
Stu,
Ha Ha, I like that, used to be as in probably no longer there.
508241
Reply By: Philip A - Sunday, Jun 17, 2007 at 10:52
I just saw in a 4WD Mag buying guide that the AFAIK Rodeo cab mounts can fail.
Have a look at em.
Regards Philip A
247409
Follow Up By: Member - David L (NSW) - Sunday, Jun 17, 2007 at 11:38
Philip A,
Thanks for your reply, I will have a look at them too, also has a loud squeak that definitely sounds like cabin/body mounts, maybe same problem.
508239
Reply By: nowimnumberone - Sunday, Jun 17, 2007 at 12:46
also have a look at the tail shaft centre bearing if they have one.
247429
Follow Up By: Member - David L (NSW) - Monday, Jun 18, 2007 at 10:02
Thanks, they do have one and it feels alright.
508442
Reply By: darcla - Sunday, Jun 17, 2007 at 12:51
Hi David
I have 92 model With 275,000 on the clock. Suggest you have a look at the centre bearing on tailshaft & its rubber mount, check uni joints . Also the rear wheel bearings only seem to last about 100,000 Ks then you start to get a bit of vibration & noise coming up via gearstick. Spray a bit of CRC or lanotec on cab mounts one at a time & recheck if noise goes away. Also check exhaust rubber isolators & if it if hits against anything enderneath while you are giving it a good thumping & shaking around.
Hope this is of some help.
Cheers Bungarra.
247430
Follow Up By: Member - David L (NSW) - Monday, Jun 18, 2007 at 10:05
Bungarra,
Thanks for info, centre bearing and uni's feel OK. Exhaust does not seem to hit against anything. Will check cab mounts as you suggest.
508443
Reply By: Gerhardp1 - Sunday, Jun 17, 2007 at 14:04
Maybe totally off beam, but have you changed your LSD oil recently?
My old Jack, 1988 LS 2.6L, used to grumble and chatter from the diff when the LSD stuff in the oil wore out. This was most obvious when starting off and doing a right or left turn, such as at the lights.
247438
Follow Up By: Member - David L (NSW) - Monday, Jun 18, 2007 at 10:07
Thanks, sounds like different sort of noise but will keep in mind.
508444
Reply By: Mikee5 (QLD) - Sunday, Jun 17, 2007 at 19:13
Have you checked the rubber Donuts that hold the exhaust up to the body, could be the exhaust system banging around?
247504
Follow Up By: Member - David L (NSW) - Monday, Jun 18, 2007 at 10:08
Thanks Mike, exhaust does not seem to hit against anything.
508446
Reply By: Member - Jeff H (QLD) - Monday, Jun 18, 2007 at 00:09
Dave, no soln offered, and different area.
Ours started just as we set off to
Cameron corner area. Sounded like tappets, but why only in the 2500 -3000 rpm range?
Local mechanic easily found the errant pipe vibrating against the firewall, (when we got
home).
[Comic relief was the intent of my post: ours is a 2001 build, so thanks to the more serious replies. Shall keep a watch].
Jeff.
247593
Follow Up By: Member - David L (NSW) - Monday, Jun 18, 2007 at 10:11
Jeff,
Thanks mate, hoping for something as simple and cheap to fix. :))
508447
