diesel blowing black stuff!
Submitted: Monday, Jun 18, 2007 at 13:14
ThreadID: 46814 Views:2372 Replies:4 FollowUps:2
My 2.8td GQ patrol has started to blow out a black substance in the past week. If I get to it early on my garage floor I can wipe it up. After a minute or two it's fine. Is it because of the cold weather? Anything I need to worry about?
I have just done a service on it but I doubt if that has anyting to do with it.
thanks,
Reply By: Member - Toytruck (SA) - Monday, Jun 18, 2007 at 13:21
Gossy,
if you are confident that the vehicle is tuned, serviced and in reasonable condition, I would suggest it is probably a little condensation blowing out the exhaust mixed with a little carbon dust.
I wouldn't be to worried unless it starts to use water/fuel at a greater rate than normal.
I am guessing it is a small patch of black spray each morning.
Toytruck
AnswerID: 247650
Follow Up By: Member -Signman - Monday, Jun 18, 2007 at 13:23
Ya beat me to the punch....
FollowupID: 508465
Follow Up By: Member - Toytruck (SA) - Monday, Jun 18, 2007 at 15:51
Signman,
only by one minute :-)
Toytruck
FollowupID: 508487
Reply By: Member -Signman - Monday, Jun 18, 2007 at 13:22
Is it coming out of the exhaust??? It may be moisture condensation in the pipe- washing a bit of soot out???
AnswerID: 247651
Reply By: whyallacookie - Monday, Jun 18, 2007 at 13:40
Especially if you are only doing short trips abck and forth to the shops etc. Doesn't give the exhaust time to get hot enough to dry out so may make it look a lot more than it really is. If this is the case try and give it a bit longer runs because this is also what rusts exhausts out. Country cars generally don't rust the exhaust out anywhere near as quickly as city vehicles, they tend to drive further more often heating up the exhaust and drying it out.
If it really bothers you the best bet would be to have a "drip" tray or pan to catch it
AnswerID: 247657
Reply By: Gossy - Monday, Jun 18, 2007 at 14:32
this sounds exactly what it is like (seems logical after reading it!). The car doesn't do much work around town at all. It can sit in the drive for weeks without being driven (purely for camping etc). So it makes sense that there is moisture in the exhaust.
I am off to do the Simpson from Adelaide in two weeks. That should give it a good clean out!
Thanks, I can stop worrying.
AnswerID: 247663
