Auscruise Cruise Control
Submitted: Friday, May 02, 2003 at 10:46
ThreadID: 4689 Views:9829 Replies:13 FollowUps:9
I am in the process of ordering a Nissan Patrol (3lt manual) and after searching the archive's have decided on the Auscruise Cruise Control. I apparently have a choice of a stalk control mounted on the left hand side of the steering column, or a pad located in the same position as the factory installed C/Cont. I'm not sure which to get, I would prefer the pad but the installer states the stalk is more 'user friendly'. If anyone has had experience with either their comments would be appreciated. Thanks.
Reply By: Member - Bigbear - Friday, May 02, 2003 at 11:40
I have mounted a stalk criuse control on my GQ, took a little while to get used to as had been using button controls on Fairmont but after a while it grows on you. Now I just set & forget for long trips. works fine for meBush Bappo's 4WD Club
AnswerID: 18963
Reply By: tim - Friday, May 02, 2003 at 12:07
what is the price to have this cruise control fitted,because i currently have a 3 ltr patrol and would like one fitted.
AnswerID: 18967
Follow Up By: Member - Glenn(VIC) - Friday, May 02, 2003 at 12:41
I am interested in the price as well as I would like to install in my 80 series.Just Do It!
FollowupID: 11910
Follow Up By: Member - Chris - Friday, May 02, 2003 at 19:25
Tim, have just fitted one to my troopy and it cost $650 fitted with a stalk. Very good throttle response from it and a lot easier on the foot/ankle/knee
chrisChris
<- 1996 Troopy, the best!
FollowupID: 11933
Follow Up By: Member - Votlip - Saturday, May 03, 2003 at 00:40
The dealer has quoted $695 installed for the stalk. When I made phone enq's with an installer in Adelaide (I live about three hours away), they quoted about $650. I don't get to Adelaide that often so I will probably pay the extra to get it done here. I'm not sure how much extra for the pad.
FollowupID: 11944
Follow Up By: crowie - Sunday, May 04, 2003 at 13:49
Guys
Just had Autron Cruise Control fitted to my 2000 model ZD30 Patrol. Quotes in Canberra are $700.00 for auto and $750.00 for manual. Expensive but this is fly by wire stuff not mechanical. Was able to mount the buttons on the steering wheel are la Fairlane style. I believe there is some problem with the design of GUIII steering wheels which might mean fitting the stalk type unless Autron have designed a new button cluster..
FollowupID: 11984
Reply By: Michael - Friday, May 02, 2003 at 12:38
Hi Votlip, If you get a 4.2, the cruise is free on the current model, basically the same output but you get a far more reliable engine, (oooppps), now that may start something, The new 4.2 still has the same mechanical pump as the last model GU andis lubricated by the engine oil. Pumps are a problem in the 3L, if you get a doctored load of fuel, and someone mentioned a while back that the air flow meter is $1200 if it gets contaminated with dust or foriegn matter. My 4yo GU ,4.2 has clocked over 260,000 ks and has never missed a beat. One more point, if you are doing a lot of freeway driving, 100ks plus the diff ratio is lower, raising the noise level higher than the 4.2.. My thought only Cheers Michael
AnswerID: 18968
Reply By: Rhubarb - Friday, May 02, 2003 at 13:30
Having used both button type and stalk type cruise controls I have would strongly recommend the stalk.
The stalk allows you to totally control the CC without moving your hands at all from the driving postion on the steering wheel. Its a matter of just flicking your fingers in the right direction!
I would hate to go back to a button system.
Go the stalk!
AnswerID: 18970
Reply By: crfan - Friday, May 02, 2003 at 14:23
I fittetted a command auto pilot with stork and am very happy with it
it was about $350 from memory (self fitted)
they have a new model out now that mounts on the steering wheel like the factory ones must be infra-red (cordless)
I think they were about $700 but dont know if that was fitted or not.
AnswerID: 18976
Reply By: Member -BJ (Sydney) - Friday, May 02, 2003 at 15:11
Use the auscruise as it is the one nissan uses on 4.2. Was told about $850.00 fitted. Wish i was still here / Gulf in July
AnswerID: 18978
Reply By: Bob Y. - Qld - Friday, May 02, 2003 at 15:16
Have just picked up a 79 series tojo, fitted with Command cruise. It is on a stalk, and I thought it was genuine, until tried to use it, then had to resort to the directions. As the ute is turbo, the cruise matches well to 'drive by wire" set up.
Have done over 5K clicks, with no problems, and it seems to be pretty accurate, even in undulating country. Has been handy over the past couple of weeks, with double points and hefty fines for exceeding the speed limits, in Qld.
Hooroo...
AnswerID: 18979
Reply By: rors101 - Friday, May 02, 2003 at 16:57
My 2003 GU fly by wire was quoted by nissan at $850 but i paid $700. Un fortunately the guy scratched the dash etc in the process.
AnswerID: 18988
Follow Up By: muppo - Friday, May 02, 2003 at 17:37
rors101 did you get it fitted by Eurovox in Melb? I din and the clowns fitted it off centre on the steering wheel and indicator light off centre too, when I complained i was told i'm fussy, I had the coast clutch resume feature fitted and it didnt work so I took the car straight to the manufacturer and they fixed it for me, they are not too impressed with installer.
Cobra Car Alarms install them as well so go there.
Done a few thousand klms now and love it , if I had a turbo diesel I would get the clutch resume again its great.
I've had the storks before and wouldnt have one again, the steering wheel mounted buttons are much easier to use especially when you want to increase or decrease your speed by one klm at a time you just tap the buttons up or down, no twisting or turning knobs.
Cost me $690 fitted and for an extra $120 you can get three resume buttons on the wheel aswell.
FollowupID: 11932
Follow Up By: rors101 - Monday, May 05, 2003 at 08:08
It was done by a mobile man with a van - I wont bag the guy because sorta did the right thing and took $50 off - ie $650 for the by wire steering control model for a 2003 GU zd30 auto. I'ld negotiate the dealer down next time and get it via nissan ie sory i'll take delivery when you fix the scratches around the dash - the same bloke does them for my dealer as well.
FollowupID: 12033
Reply By: Member - Martin- Friday, May 02, 2003 at 18:00
I have had both and reckon the the pad on the steering wheel is the way to go, but everyone has there own opinions.As regards to buying the 4.2 over the 3litre because it comes with a cruise control what would you rather spend $850 on getting one fitted to the 3lt or $7000 more for the 4.2 because it comes standard, you dont have to be a scientist to work that one out. By the way i am on my second 3lt and have not had any problems at all with either of them very reliable enough power to tow a fully loaded double horse float every weekend for hours on end and very good fuel economy, technology is wonderfull but obviously some people will never be convinced and think the bigger the better.
AnswerID: 18993
Reply By: Phil P - Friday, May 02, 2003 at 18:26
I had the Nissan Dealer organise the cruise control (fitted today) on a 3L Auto ST Patrol. The brand is Autron. Cost me $660 (includes GST).
Buttons are on the steering pad.
I have another car that has the stork type control & another with the steering pad buttons. Bottom line is you get used to both types.
Phil P
AnswerID: 18996
Follow Up By: rors101 - Monday, May 05, 2003 at 08:11
Phil if it is the fly by wire then you got a bargain otherwise the pedle puller ones are about $100 cheaper - Both made by Autron.
FollowupID: 12034
Reply By: herkman - Friday, May 02, 2003 at 20:34
My Nissan dealer told me, that the cruise control as an after market fit, does not work under 80 Kph.
May pay to check this statement out with anp prospective suppliers.
Col Tigwell
AnswerID: 19006
Follow Up By: Member - Bonz (Vic) - Saturday, May 03, 2003 at 15:17
Col,
I have a auscruise and it works down to 30kph and got the wheel buttons and didnt look back, made the car much easier to drive under the revenue collection limit________________________________>
Fraser Island Dreaming
FollowupID: 11961
Reply By: Member - Votlip - Saturday, May 03, 2003 at 01:00
Thanks for your quick responses and opinions. I have had C/Control for the last two years on my Commodore (factory fitted) and wouldn't be without it. I will probably get the installer to show me where both get fitted and see which one looks the best. I agree with Phil, I think you get used to whatever you have. I wasn't sure if anyone knew of any problems with either.
My wife said that she isn't that interested in getting C/Control as she doesn't use it. I don't know where she got the idea that she would be driving it! ;)
AnswerID: 19024
Follow Up By: Member - Votlip - Saturday, May 31, 2003 at 01:04
Just to follow up, I collected my New Nissan patrol yesterday and can't stop smiling :-). I chose the pad (auscruise) in the end, it sits between the spokes on the rhs of the steering wheel in the same place as the factory fitted, and it fits in very nicely. The stalk looked good, but with indicator and wiper controls there was enough sticking out already. Seems to work fine and cost $695.
FollowupID: 14027
Reply By: Member - Errol (WA) - Saturday, May 03, 2003 at 18:57
Ive got a 4.2 td Nissan ( check out the pic,s ) with Auscruise fitted . The pad is the way to go . It sits under your left hand , inbetwen the spoaks . The only thing , i feel that its upside down . you,ll see what i mean , once you get use,d to that , its grate .You don,t have to take your hand off the wheel ,you don,t have to look down , you can do it all by feel and its quite unobtrusive , unlike a stork would be . I woudn.t be without it now .Why go overseas when you can ExplorOz
ERROL
AnswerID: 19066
