Oziexplorer to Magellan
Submitted: Sunday, Jun 24, 2007 at 16:26
The Yeti
Gday, does anyone know of a converter to change oziexplorer track files (plt) to magellan files (log). Have got Oziconverter but that goes Magellan to Ozi. Trying to download some of my old files into new gps
Thanks The Yeti
Reply By: The Explorer - Sunday, Jun 24, 2007 at 16:32
GPSBabel also does it ..
www.gpsbabel.org/
and OziExplorer obviously, but I am not sure what functions are disabled on trial/demo version (assuming you dont already have registered copy).
248758
Follow Up By: The Explorer - Sunday, Jun 24, 2007 at 16:36
Also - keep in mind that Magellan have a 2000 track point limit - if you upload a track longer than this all points after the 2000th will be missing. Another reason to get OziExplorer - you can filter out points to 2000 in a manner that retains entire track length (but you lose some detail in middle) or you can break the track up into sections and upload individually.
509670
Reply By: The Yeti - Sunday, Jun 24, 2007 at 17:15
Thanks Explorer, I have Oziexplorer and they are the old tracks I want to convert, but cant get Ozi to go to Magellan only the other way around. However downloaded GPSBabel and works great. Thanks very much.
The Yeti
248764
Follow Up By: The Explorer - Sunday, Jun 24, 2007 at 18:57
No worries- OziExplorer does it, so not sure why you cant - if you have latest version and settings are right just use Magellan Menu on top of screen. If this doesnt work check for program update and/or go to Configuration (in File Menu) and make sure you have Magellan USB selected under GPS model.
509689
Reply By: The Yeti - Monday, Jun 25, 2007 at 11:26
Thanks Explorer,I had a proper look and changed to Magellan USB. BRILLIANT! Now it works a treat. I am much better behind the wheel than behind the keyboard. I appreciate your help thanks again.
Yeti
248912
Reply By: Member- Rox (WA) - Monday, Jun 25, 2007 at 23:50
The Yeti, I use the Gps to do it OSI ex + Discover Oz
249146
