Spin on filter.
Submitted: Thursday, Jun 28, 2007 at 20:23
ThreadID: 47212 Views:2787 Replies:6 FollowUps:10
Spin on filters have been the greatest thing since sliced bread, but if they only could be made more excessible on some of these motors!!. Ever had a oil filter flip over in your hand just as you wind it off the last thread!!?, and all that black chit runs up the inside of ya overall arm!! .I often wonder why the filter has to mounted directly on the engine block, as to being mounted in a separate housing somewhere making it easier to service. Its ok if you have the luxury of a hoist, but its not the case with clumsy ol me.
Cheers Axle.
Reply By: TD100 - Thursday, Jun 28, 2007 at 21:10
i agree but why has holden gone back to stinkin cartridges on the alloytec V6s after all these years??????cheers bewildered
AnswerID: 249729
Follow Up By: Andrew-rodeo - Friday, Jun 29, 2007 at 21:49
Pollution!! there is less waste with cartridge type filters.
FollowupID: 511030
Reply By: Stu050 - Thursday, Jun 28, 2007 at 22:44
The 1HZ has the effing thing mounted upside down, so all that black chit escapes everywhere anyway.
AnswerID: 249759
Follow Up By: Member - Axle - Friday, Jun 29, 2007 at 07:31
Same as some of the isuzus, a real pain!.
axle.
FollowupID: 510805
Reply By: fisho64 - Thursday, Jun 28, 2007 at 23:11
go to an auto shop and you can get a remote filter kit for around $150 or so, then put it where you want!
AnswerID: 249767
Reply By: Michael ( Moss Vale NSW) - Thursday, Jun 28, 2007 at 23:34
So you reckon that sliced bread is the benchmark??:) Michael
AnswerID: 249773
Follow Up By: Member - Axle - Friday, Jun 29, 2007 at 07:44
DEFINATELEY!!!, After watching kids trying to cut a unsliced loaf with a not so sharp knife...lol.
FollowupID: 510807
Reply By: Member - Roachie (SA) - Friday, Jun 29, 2007 at 08:20
Check out www.amsoil.com and see the type of set-up I use.
I have my oil filters (one standard and one by-pass type), mounted on the inside of the chassis, just down the back in front of the rear wheel. I've made up a protective plate to ensure they don't get holed by a stone etc.
Unless I have a catastrophe (of my own making), I can get anything up to 80,000klm out of an oil change too (using their 100% synthetic oil of course). Best I've done to date is 33,000klm on the old 4.2TD that I sold recently. Oil was still quite okay as per analysis I get done regularly.
AnswerID: 249788
Follow Up By: Member - Axle - Friday, Jun 29, 2007 at 08:48
That is a very efficient system as far as filtration goes!, So how often do you have a analysis done?
Cheers Axle.
FollowupID: 510821
Follow Up By: Willem - Friday, Jun 29, 2007 at 10:52
Every time there is an oil spill.....lol
FollowupID: 510853
Follow Up By: Member - Roachie (SA) - Friday, Jun 29, 2007 at 21:56
As Willie has so subtly alluded, I haven't had the current belly-full of oil in the Chev long enough to have it analysed yet.
However, when I had the 4.2TD , I was getting it done about every 7,500klm or so.
Once you get comfortable with how long you can let it go, it isn't so important to do it as frequently I guess.
You still need to change the filters about every 15,000klm. Makes a change from the factory idea whereby you change your oil every 5000klm but only worry about the filters every 2nd change.
FollowupID: 511033
Follow Up By: Jimbo 2121 - Sunday, Jul 01, 2007 at 12:47
How much does it cost to get the oil analyzed? I've always thought that it is cheaper to just change the oil in a car rather than get it analyzed.
On all of our larger equipment at work we get the oil analyzed, but that is because some of these machines take hundreds of liters of oil. It also gives you some idea of what is wearing out in the machine by telling you what metals were found in the oil.
FollowupID: 511282
Follow Up By: Member - Roachie (SA) - Sunday, Jul 01, 2007 at 18:15
Jimbo, about $33- per test. I don't believe it's necessary to get the tests done as frequently, once you've established the benchmark figure. I will only get the analysis done every 20,000klm or so, once I've done that many klicks (without dropping my load on the highway somewhere)......hahaha
FollowupID: 511322
Reply By: Member - Stephen M (NSW) - Friday, Jun 29, 2007 at 11:00
Hi Axle, mate try the filter on a V6 prado 95 series what a pain in the ars#. Need an extra foot on your arm an about 2 inchs in diameter to get your arm in. First filter change I took off all the bash plates under radiator,oil pan, auto box etc thinking I could get to it WRONG !! Rang my mate up as i had already droped the oil out so wanted to put fresh oil in with new filter not old filter. Pull the rubber flap off on the passengers side front inner guard just behind and infront of the wheel. OK no problems, ah yeah and how do I get my arm to reach across a metre to get the oil removing tool on, ah yeah need to buy the correct tool from toyota that goes directly over filter then 1/2 inch extension bar to a attach to my 3/4 socket. So $100 bucks later I now have the correct tools to do the job. Old hilux was just soooo easy to change but at least I only have to do the prado every 10k instead of every 4k. My mate has the 120 petrol what a beauty right at the top and even has a drain around it. Regards Steve M
AnswerID: 249820
Follow Up By: Member - Axle - Friday, Jun 29, 2007 at 12:32
Hi stephen, Told ya to buy a landrover,:))))))) no problem getting the filters off them!
Just pour oil in the top and wait till it runs out the bottom.
Know what you mean about special tools, rover are good at that caper!.
Cheers Axle.
FollowupID: 510874
Follow Up By: everydoghasitsday - Saturday, Jul 07, 2007 at 01:11
OR on that note to buy a nissan :))))) easy to work on too,But they do take a special tool to drive 1 :)))LOL LOL ha ha ya got to love that LOL
FollowupID: 512316
