new 70 series cruiser problem
Submitted: Friday, Jun 29, 2007 at 19:51
trolute
Hi All,
We have had a bit of a problem with our nice new 70 series troopie this week. it was coming back to the community when it stopped to give someone a jump-start, and in the process, it died. it was taken back to alice, and the mechanic told us today that we fried its computer. This has never happened on our old models, but of course they don't have computers. is this a
sign of the future - sensitive electronic workhorses?
Reply By: kimprado - Friday, Jun 29, 2007 at 20:09
Trolute
It sounds as though the Jumper leads have been set up incorrectly. With computer controlled cars you need to be careful.
Kim
249914
Reply By: Graham & Lynne - Friday, Jun 29, 2007 at 20:26
you need to have a 'anti zapper' on you jumper leads cost approx $70 made by 'Matson' buy from Repco.
also connect negative lead to engine block on 'dead vehicle' NOT BATTERY NEGATIVE TERMINAL on 'dead vehicle;.
249919
Follow Up By: jeffwa - Friday, Jun 29, 2007 at 20:48
No you just need to connect the negative to a metal earth contact OTHER than the battery on the car with the flat battery. Most anti zappers will only tell you if you have incorrectly connected them and the leads I've seen with anti zapper devices in them have been thin poxy things anyway, not like my old truck leads that I think were made out of welding cable.
But anyway, I've jump started heaps and heaps of cars with ECU's (including my diesel surf) both with direct battery contection (old school) and by doing it to some other earth and never had a drama....
I would be suprised if they were that sensitive, perhaps just a once off. But when you're jumping cars it's good practice to earth the black lead on the car with the flat battery to a metal part on the motor, say the hook that you use to crane it out or similar. It just becomes habbit after a while, I've been doing that for the last 10 years!
510994
Follow Up By: Aandy(WA) - Friday, Jun 29, 2007 at 20:57
Connection to the engine block is not to prevent zapping the computer. It's to reduce the chances of a battery exploding. It doesn't matter where you make the second earth connection (I use the wheel nuts) as long as it's away from the battery. The final connection can be on either vehicle. The procedure is thus- 1.Connect positive to positive.
2.Connect one clamp to negative battery terminal on onne vehicle and complete the circuit by clamping to an earth point
well away from the battery of the second vehicle.
It's the final connection only that produces sparks. The sparks pose a risk as batteries produce hydrogen which is a very flammable gas - remember the Hindenberg disaster?
511001
Follow Up By: jeffwa - Friday, Jun 29, 2007 at 21:22
Yes I understand it helps prevent explossion (not that I've ever seen or heard of such a thing while jump starting, but I guess it's possible).
The RAC magazine stated that this was how to jump start a car with a computer as
well, have been doing it ever since, never blown a computer. I jump started two cars just last week and mines got an ECU for the engine, a computer for the gearbox and a computer for the 4wd system. But I've jump started a tonne of petrol ECU vehicles in the past without issue as
Last week I jumped a 4.2 patrol and a diesel hilux, I've also recently jumped a feroza (EFI 16 valve motor with an ECU) and
mine has an ECU.
511016
Reply By: Member - JohnR (Vic)&Moses - Friday, Jun 29, 2007 at 20:38
won't be the last one I imagine
249923
Reply By: Andrew from Vivid Adventures - Friday, Jun 29, 2007 at 21:10
One assumes they still have instructions for jump starting in the manual... presumably you were following them, so it is their issue.
249935
Follow Up By: trolute - Friday, Jun 29, 2007 at 21:32
Its a government troopie, so if there was ever a manual with it, it has already been used to start a fire, or thrown out the window to reduce weight etc...
As for getting it fixed, again, since its a government car, warranty is never an issue - if only everyone had such a good relationship with the manufactorers
511023
Reply By: Nick R (VIC) - Friday, Jun 29, 2007 at 21:17
I was once told that to jump start off a vehicle with a computer that you should have the engine off when you apply the leads and then start the "donor" vehicle.
I think the principal is that any voltage spikes that go through the electrical system happen before the computer is doing anything and any variance that occurs from the other vehicle starting should not cause problems.....
I am not sure of the quality of this advice........
NickR
249937
Reply By: bobby 6 - Friday, Jun 29, 2007 at 21:20
another little trick i was told a long time ago when jumping to cars with computers turn the lights on on the that car,apparently any spikes or similar i was told will usually blow the lights instead of the computer.
249939
Reply By: Eric Experience - Friday, Jun 29, 2007 at 22:01
Trolute.
The computer is probably ok, Take it to an auto electrician for a proper diagnosis. The computer has its own built in protection, it is most likely a fusible link. Eric.
249950
Follow Up By: Member - Terry G (NSW) - Saturday, Jun 30, 2007 at 07:43
I agree. Thats the way Mr Toyota usually has it set up. The Link will go first.
tg
511075
Reply By: Graham & Lynne - Friday, Jun 29, 2007 at 22:02
The Matson anti zapper I mention is just that you retro fit it to you jumper leads.
The reason you earth to engine block on dead car is to stop spikes from loose or poor connections on dead battery.
249951
Follow Up By: F4Phantom - Friday, Jun 29, 2007 at 22:44
now that is the only logical answer I have heard so far to not directly connecting to the battery. Hydrogen gas! I dont think so, and as for the other stuff its all nonsense, but its very true that many cars connections are loose so you could potentially have power cutting in and out a lot, also the battery could be dead because its not charging properly (loose) so in the case of a dead battery the probability that a connection is loose is much higher.
511045
Follow Up By: Member - Phil G (SA) - Friday, Jun 29, 2007 at 23:36
Reason to use the block for the earth is so that you don't blow your head off with a hydrogen explosion. Hydrogen is not just flammable, its explosive, and its given off from lead acid batteries. Its pretty easy to get a spark on a battery terminal when connecting or disconnecting a jumper lead. Do a google on "car battery explosion" if you want to know more.
511053
Follow Up By: F4Phantom - Saturday, Jun 30, 2007 at 10:18
yeah I know about hydrogen and batteries, I once put 25 amps through 3 massive batteries over over a weekend and filled a whole factory full of hydrogen gas, on monday morning we had to sneak around carefully (no sparks) opening doors to allow the gas to escape. The point is, I have noticed that although batteries do give off H gas it does take time and the short time it takes to spark a battery is not enough, also its the lightest element and tends to escape very rapidly. I know batts can explode but they would have already had a build up of hydrogen inside and the build up would not because of you sparking the terminal. This raises the next point of course that its still a safe practice, as I only disagree with the part about making H gas on
the spot, not the part about it exploding batts.
511113
Follow Up By: Member - Matt Mu (Perth-WA) - Sunday, Jul 01, 2007 at 17:03
F4 it doesnt make hydrogen in the instant you jump start the vehicle the gas is in the air gap above the electrolyte!
Argue as much as you like with people that know better but they are imparting knowledge for your safety.
When you connect the LAST connection before jumpstarting a veh...the Earth on the flat vehicle that is when the good battery immediatly starts to supply the flat battery with power and that connection WILL spark as you connect.
So instead of connecting at the earth post on the battery and having the spark ignite the gas at the little breathers and turn your battery into a hyrogen bomb with molten lead and acid exploding into your face....connect it on the block, lifting point on engine anywhere close to starter motor and you will be safe.
Hey but if you know better then argue and do it your way and we will hear about it one day on this
forum anyway!
All the best
Matt.
511307
Follow Up By: F4Phantom - Sunday, Jul 01, 2007 at 17:12
My last post is kind of thoughts out loud, and you can see I concluded myself what you are saying, as initially my understanding of the question was that H is made on
the spot, I then realised we are talking about residual H gas. So from this point of view I was not actually arguing with what you are saying right now.
511311
Follow Up By: Member - Pesty (SA) - Sunday, Jul 01, 2007 at 19:34
I know a bloke who was severly injured many years ago, when he made a spark over 2 massive batteries on a drilling rig and they exploded, which has made me consious of it ever since.
Pesty
511341
Reply By: Member - Phil G (SA) - Friday, Jun 29, 2007 at 22:54
Plenty of differing info out there, so I'll throw 2c in as
well... I also have a diesel with ECU.
#1 If their battery is dead flat, I get some charge back into it before attempting to crank their vehicle, so I hook up the jumper leads, then start my vehicle and run it at say 2000rpm for 5 minutes, by turning up the hand throttle.
#2 I turn my vehicle off before cranking the other vehicle and
#3 I jump from my auxiallary battery, because I can isolate it from the rest of the electrics.
And if the Troopie wouldn't start, it may be worth pulling some fuses to reset the ECU, and see what happens.
249960
