Amps/hr for 50 litre 12v fridges ?
Submitted: Saturday, Jun 30, 2007 at 09:52
The Birds (WA)
Gday,
Anyone know a reasonably accurate figure for amps used per hr for a 50 litre Waeco or engel if used as a freezer or a fridge ?
Looking at purchasing 2 of them - 1 to use as fridge and 1 to use as a freezer ?
Seems to be a lot of conflicting information. The Waeco catalogue for example states an average of 0.86 amps/hr with 5 degree interior at 32 degrees ambient temperature. Fair bit different to some other figures quoted on previous posts
P.S - Not meant to be another 'Waeco vs Engel question", purely after figures !
Hooroo
Reply By: Mike Harding - Saturday, Jun 30, 2007 at 10:03
I'll guess that, when the compressor is running, about 4A. The difficult question is... how many hours per day will the compressor run? That depends on external issues such as ambient temperature, additional insulation, how many times you open it...?
Mike Harding
250001
Reply By: Russ n Sue - Saturday, Jun 30, 2007 at 10:21
We use two Waeco's, one as a fridge and the other as a freezer. They both have the same compressor even though one is a 40l and the other is a 50l. When running they each draw between 3.0 and 3.3 Amps. If you use the worst case example, then you will use 3.3A/H for the freezer and a bit less than half of that for the fridge. This assumes a worst case duty cycle of nearly 50% for the fridge.
So if you allowed for 5.0 A/H in your calculations or 120A/H for a day you would be way over the top, but it would enable you to calculate what energy you need to replace.
Now for the reality. The duty cycle is usually much less than above if the fridges are out of direct sun and
well ventilated. Ours have never exceeded 68 A/H for a single day of use. (Our solar regulator keeps a tally of incoming and outgoing A/H.)
Russ
250007
Reply By: Crackles - Saturday, Jun 30, 2007 at 10:48
Birdy results are conflicting as there are so many variables.
.86Ah is on the conservitive side & in reality closer to 1.2Ah, a freezer may use around 1.5. As an example a 40L fridge will not last 3 days on an 85Ah deep cycle battery in 30 degree heat. When working out battery or sloar panel sizes, allowance will need to be made for hotter days which can almost double consumption depending mainly on the fridges insulation & ventalation.
If space allows it would be more efficient to have one larger fridge/freezer combination unit than 2 separate ones.
Cheers Craig........
250013
Reply By: D-Jack - Sunday, Jul 01, 2007 at 22:23
Engel draw a max of 2.5 amps/hr in a 40L fridge. 4.2 in a 57/60L fridge or fridge/freezer combination. Many people have gone Engel over Waeco for the edge on consumption they have.
250225
Follow Up By: D-Jack - Sunday, Jul 01, 2007 at 22:29
...continued...although this 'article'
says differently, but I'd take it with a pinch of salt given the above replies, and the fact that Waeco probably paid the most to the magazine doing the test.....heee heee
511379
Follow Up By: D-Jack - Sunday, Jul 01, 2007 at 22:31
try again....
icle
511380
Follow Up By: D-Jack - Sunday, Jul 01, 2007 at 22:32
doh I give up, you get the idea
511381
