What would be the Bare Essentials???
Submitted: Sunday, Jul 01, 2007 at 18:30
ThreadID: 47290 Views:3674 Replies:8 FollowUps:11
Hi all, As a relitive new commer to four wheel driving I want to ask what would be the bare essentials in the way of recovery gear and spares to carry on a 2 to 3 day trip to Fraser Island. Do I need to go out and buy a winch or should I just carry a snatch strap???? That sought of thing. My vehicle is a 2000 Hilux diesel. Any advice would be very much appreciated.
Cheers to all.
Reply By: Kev M (NSW) - Sunday, Jul 01, 2007 at 18:35
Rated front and rear recovery points,
a couple of rated shackles,
Snatch strap,
long handle shovel,
elbow grease,
base plate for jack,
equaliser strap.
With the amount of traffic on Fraser I wouldn't think you would need a winch
Cheers Kev
Russell Coight:
AnswerID: 250184
Reply By: Barnray - Sunday, Jul 01, 2007 at 18:44
I Think that a tyre gauge would be your first most important purchase, I have traveled from top to bottom on Fraser and used the gauge to lower to 15psi to rescue another vehicle. I stopped to help a bloke stuck in a track behind a headland, I had my tyres at 18psi and when I tried to take off all I did was start digging to China so I let 3psi out all round and was able to drive out and pull the other vehicle out at the same time. A snatch strap and shovel are about the next best, a winch if the funds allow. barnray
ps they recomend using 18psi on the Island. b
AnswerID: 250186
Follow Up By: Kev M (NSW) - Sunday, Jul 01, 2007 at 18:49
Yeah,
I forgot that one,
also consider a compressor for reinflation.
Kev
Russell Coight:
FollowupID: 511333
Follow Up By: Nick R (VIC) - Monday, Jul 02, 2007 at 09:01
Tyre pressure is always the key, about 12lb in the 80 series when we went to fraser and it didn't look like stopping except one place on the east side where it is suggested that you don't drive!!! even then it just took some more herbs as there was no wheel slippage....
NickR
Carpe Cerevisi
FollowupID: 511425
Reply By: Member - Phil G (SA) - Sunday, Jul 01, 2007 at 20:22
Only thing I can add to the great advice above, is the shackles should be 3.25T - no higher, and no lower.
Next step is to learn how to use it - any chance of a little 4wd training before you go?? Maybe through a club or a 4wd course. Its just that its pretty easy to stuff up a snatch recovery, and do some damage to vehicle and yourself.
AnswerID: 250199
Follow Up By: Member - Kiwi Kia - Sunday, Jul 01, 2007 at 21:06
Phil, Why do you say that shackles should not be rated over 3.25T ?
Other then the physical size (and weight) I don't understand why you should say this.
FollowupID: 511359
Follow Up By: Member - Phil G (SA) - Sunday, Jul 01, 2007 at 21:20
Kiwi,
The most dangerous thing that can happen during a snatch recovery, is that a recovery point breaks, and you then have a flying missile attempting to kill the guy in the other vehicle. The bigger the shackle, the bigger that missile will be. Shackles never break during recovery (they don't break until about 30T when tested). So to put anything bigger is unnecessary and increases the level of danger.
FollowupID: 511362
Follow Up By: Member - Phil G (SA) - Sunday, Jul 01, 2007 at 21:46
I guess to follow on,
Everything should be stronger than the strap. If anything were to break, then a broken strap is least likely to cause injury. So the chassis mounted recovery points need to be the strongest points - its very hard to get them rated these days. Many of us rely on the factory towing points, but if you can easily mount the 10,000lb hooks directly to the chassis with HT bolts, then thats the best option. Hooks are preferable to loops because they do not require shackles.
At the front, to increase safety, an equaliser strap (sling between two chassis mounted recovery points, and through the loop of the snatch strap) is best used - it halves the load on each recovery point, and should a recovery point break, the broken point and shackle will be retained by the opposite side. It also is kinder to the vehicle chassis.
At the rear, the square hitch towbar is most commonly used. Most people simple slip the hitch pin through the loop of the strap. They don't break. Some people say they bend, but only with a huge amount of force. The towbar manufacturers say "no way", but they are covering their butt. Towbars are attached to the chassis on both sides with a minimum of 4 HT bolts, so are a good recovery point.
Best to use no shackles at all. Then theres no extra potential "missiles". So Towbar to towbar is best, because it usually means no shackles, and the vehicles are mechanically stronger if pulling in a forward direction. Front to front is the worst, and to be avoided.
And if you minimise the required force by a bit of shovel work, then you're better off.
Most 4wd recovery is usually a mild tow or small snatch, but if you are in a situation where mud or wet sand are involved, you'll need to make it all as safe as possible.
FollowupID: 511372
Follow Up By: Member - Kiwi Kia - Sunday, Jul 01, 2007 at 22:07
Hi again Phil, I agree with all your reasoning. I was just wondering why you emphasised that you did not recommend any shackle with a higher rating ("no higher, and no lower").
I will be involved with recording the actual forces during snatching of bogged vehicles next weekend, weather permitting, we don't want to get the data logging equipment wet :-)). It will be very interesting to see if the calculated forces actually do occur. We have tested recovery hooks to destruction on a static test rig with some interesting results regarding the failure of some factory fitted hooks but all the after market forged hooks reached their rated values before straightening. It should be noted though that some did not have any significant safety margin above the rated value. I will pm the dynamic results if you are interested.
FollowupID: 511375
Follow Up By: D-Jack - Sunday, Jul 01, 2007 at 22:10
I don't think it would really matter if you got hit with a 3.25T shackle in the event of something letting go or 5T - either way I think you're in serious trouble!
FollowupID: 511377
Follow Up By: Member - Phil G (SA) - Sunday, Jul 01, 2007 at 22:47
Kiwi,
Just weighed the two - 3.2T shackle is 650gm, while the 4.75T is 1050gm - so its 400gm heavier - I think thats a significant difference for no gain. They will both do a lot of damage, but a bigger shackle may get thru a cargo barrier, and a headrest, as well as the rear windscreen.......
"No lower", just because the shackle needs to be strong enough, but have to admit to having a sling and two 1 1/2T shackles for the Subarus I've had in teh past.
Great to hear that someone's doing some testing with the factory points. I remember some interesting info coming out of WA a few years back with the 80series loops - the loops were actually stronger than the 12mm HT bolts that held them on - most people assume it would be the other way. Also, our club did some demos of shackle damage some years back - loaded a snatch strap with a 3.2T shackle, and let it go - the shackle went straight through sheets of 20mm ply. We were actually looking at air brakes, and demonstrating how useless they were - found that a heavy item like a drag chain, draped over the strap was much more effective in slowing down a shackle.
Its interesting stuff - way too many myths out there
FollowupID: 511383
Follow Up By: Member - Kiwi Kia - Monday, Jul 02, 2007 at 08:11
100% agree Phil, For years I have been trying to tell people that 'air brakes', parachutes or dampeners' were useless. However, I do believe that a brightly coloured item certainly should be used as it acts as a warning to others who may not see the strap / rope etc.
FollowupID: 511414
Follow Up By: Member - bushfix - Monday, Jul 02, 2007 at 19:12
g'day Phil,
re the drag chain, that is what I use, but not just to slow things down, it should also keep things lower to the ground rather than the potential of reaching above the waist. "risk management" i guess eh?
FollowupID: 511519
Reply By: kiwicol - Sunday, Jul 01, 2007 at 20:37
the only vehicle i have seen on both frasier and morton island that have had problems are the soft 4 wd with no low range and no clearance, so with lowering tyre pressures you will have no problems, so enjoy. Col
AnswerID: 250201
Reply By: Truckster (Vic) - Sunday, Jul 01, 2007 at 21:24
First thing I would recommend is driver training... then you will understand for yourself what you need to take and how it all works safely.. you dont want some pole smoker doing the wrong thing adn you ending up with a towball for a nose..
AnswerID: 250211
Follow Up By: 4be - Monday, Jul 02, 2007 at 19:05
Thanks for the driver training bit. I had training around 8 years ago when I was with the RAAF. But I do think I need to brush up though.
FollowupID: 511515
Reply By: Member - extfilm (NSW) - Sunday, Jul 01, 2007 at 21:58
I would only take a tyre gauge on my first trips to fraser island. prior to that the maniac 4wd back packer tours do not even have a tyre gauge...... they have no idea with no recovery items. but having said that they are very limited as to where they are allowed to go.
AnswerID: 250218
Reply By: Member - Brian (Gold Coast) - Monday, Jul 02, 2007 at 07:18
4be,
Find a club that does driver training, or a driver training centre near you and do a course. That's the easiest way. Driving Fraser Island can be the most fun you can have, or it can be your worst nightmare if you get it wrong.
I agree with most of the comments above, a shovel, tyre guage, snatch strap (and strap dampener) and rated shackles, would be minimum recovery equipment.
The trick with sand driving, particularly on Fraser where the sand, although soft in places, is not as soft as other beaches, when you feel the car digging in, STOP! reverse back, get a bit more momentum up and go a little harder.
Brian
AnswerID: 250248
Reply By: TassieDave - Monday, Jul 02, 2007 at 10:02
G'day
i've not long been back from Fraser towing a two tonne van, I didn't even look like getting stuck. The fellow I was with got bogged at Inskip, tyre pressures are the key. I had mine at 15psi, his were still at road pressure. So other than a tyre guage, I recken an extra case of beer for the backpacker's to push you out would be be good.
AnswerID: 250271
