AnswerID: 250203 Submitted: Sunday, Jul 01, 2007 at 20:49
_gmd_pps
replied:
Air Bags is the way to go .. I assume you have a single rear wheel otherwise you would hardly ask for leaf spring upgrade ..
I have a dually GMC and have a 2" level lift in the front with dual shock hoops from Cognito Motorsports. I also have their pitman/idler support braces and tie rod sleeves to strengthen the steering .. in the rear I have airbags for additional support when I am fully loaded with the slide-on and the 4.5t boat trailer. All shocks are Bilstein - in the front 4 and 2 in the rear ... There are a few US accessory shops in the
Brisbane area I had contacted before I actually purchased the vehicle and decided to import all the parts with it .. they usually stock stuff for older models, because they say that the demand for the latest model is low or non existent ...
If you primarily want to do something in the rear Firestone Airbags are my suggestion. If you can buy the model specific brackets here I don't know ..
I got some stuff from summitracing.com and had it shipped to the dealer where I purchased my vehicle ...
Mr. Airbag has the Firestones here in OZ but probably not the mounting brackets for the GMC ... expensive to ship because it's heavy and USPS does no sea shipments anymore ...
In the front I doubt you get anything here in OZ. Cognito is the way to go but
shipping is also expensive since they only ship UPS and the stuff is heavy ...
will cost you several hundred $ US to ship a front
suspension upgrade by UPS.
You can ask Eagle Parts and other US suppliers here if they can order it for you because the have containers coming on a regular basis and it might turn out cheaper that way, but I seriously doubt they deal with Cognito ... but I can be wrong ... the prices I was quoted here were off quite a bit when one has the opportunity of free shipping with the vehicle ...
good luck with your venture
gmd
Reply 1 of 2
