Intermittent speedo reading, 04 Prado TD
Submitted: Sunday, Jul 01, 2007 at 21:50
Prado Dave
Out driving around Straddie today, and noticed the speedo needle was slowly moving between 0 & 40 while travelling at constant 40. The needle then dropped to 0. A bit later (after the kids showed me where Mum had driven the trailer through some deepish
water - looking for a
campsite she said!!) needle was back up again, seems to be OK since. Any
bright ideas? Thanks, Dave.
Reply By: Member - Stephen M (NSW) - Sunday, Jul 01, 2007 at 21:55
I would say possibly Dave you got a bit of
water in the speedo sender unit terminals and then dried itself out ?? Just a guess Regards Steve M
250216
Reply By: Prado Dave - Sunday, Jul 01, 2007 at 22:11
Yeah thanks Steve that was my first thought, but we'd travelled about 80 km since the "depth test" and it was 2 days later as
well. Only been home a while, too cold to have a look underneath, presumably the sensor is on the side of the auto somewhere. Cheers, Dave.
250221
Follow Up By: Member - Jiarna (NT) - Sunday, Jul 01, 2007 at 23:43
Hi Dave
The connector is protected by a small O-ring type seal, which may have allowed a little
water to seep in. The the famous Toyota electrical gremlins were able to wreak havoc in the connector until it finally dried out. The O-ring seal would have kept the
water in once it got in.
511400
Reply By: Skippy In The GU - Monday, Jul 02, 2007 at 00:14
Hi Prado Dave does the odometer still click over
250242
Reply By: Wazza - (Vic) - Monday, Jul 02, 2007 at 19:51
Dave,
If you do find it is the speed sensor, try the wreckers first as it should be about $30-40. Toyota will want $300-400+
Had the exact same symptoms on my 80 series manual. Did it for a day or two and then came good for a couple of months, then did the same flickering and then dead.
There may be other cars that the sensor will suit as
well, I think the 80 series shared it with certain Celica's and others for example. The list of suitable cars comes up on the parts catalogue at the Toyota dealer. The sensor I got in the end from the wrecker had a different part number to the original one I pulled off, but works
well. Speed checks ok with the GPS anyway.
Hope you track it down, annoying isn't it?
Wazza.
250371
