Site Search
Section Image
GU 4.2 oil leak at sensor.
Submitted: Monday, Jul 02, 2007 at 09:37
Austravel
I've got an oil leak in the front of a GU, towards the top of the engine where a set of wires run to what I believe might be a sensor. I recall sometime ago reading about oil leaks from the speedo sensor being common. Is this the case? Any ideas on a fix, this is the second time it's happened, first time under warranty?
Advertisement
ThreadID: 47310 Replies: 1
Views: 326 FollowUps: 1
AnswerID: 250288   Submitted: Monday, Jul 02, 2007 at 12:15
Member - joc45 (WA) replied:
sounds like the tacho sensor, mounted high on the timing cover, just below the water outlet, with a pair of wires which come out. It's a relatively solid block, and I doubt if oil would seep thru it. I suspect that a new gasket and sealant will probably fix it.
I've owned a GQ and a GU and never had problems with the sensor.
Gerry
Winderabandi Bay
Click Image to Enlarge
Beach Heaven - Winderabandi Bay, Ningaloo
Reply 1 of 1
FollowupID: 511459   Submitted: Monday, Jul 02, 2007 at 14:21
Austravel posted:
Thanks Gerry,
That'll be the one. Wasn't sure how it sealed, if it's just a gasket it'll be easy to replace.
Thanks again.
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
