Turbos - Water or Oil Cooled???
Submitted: Monday, May 05, 2003 at 14:01
JackLivesHere
Will be buying a 4cyl Turbo Diesel shortly and have question cooling. The Courier / Bravo range have
water cooled turbos. Is this a major benefit over the oil cooled units??
Reply By: Truckster (Vic) - Monday, May 05, 2003 at 14:45
Oil cooled uses engine oil, which causes it to heat up lots more, and thus wear the oil quicker.
Water cooled, also use seperate
water container on some, which then takes the heat away from the motor...
try
www.are.com.au
www.dencodiesel.com
19171
Reply By: phil - Tuesday, May 06, 2003 at 09:46
I think most, if not all, original equipment turbos are now
water cooled. In addition they are also oil lubricated by the engine oil.. The cooling seems to be directed at the bearing area between the exhaust turbine and the compressor .
I have a 2000 Bravo "Cab Plus" tray back. The latest version with the doors to the rear area looks like a real winner. Fantastic storage.
Heading to the Flinders next week.
19233
Reply By: JackLivesHere - Tuesday, May 06, 2003 at 10:01
Thanks guys.
19237
