Pump position
Submitted: Tuesday, Jul 03, 2007 at 17:52
jonnyNo1
Hi, I have just purchased a power steering set up for my HJ45 with H motor. Unfortunately the pump has had a hand made bracket made for it and I have no idea where it is supposed to bolt up. Has anybody seen one of these pumps in situ with its bracket? I would love to know and would welcome any sketches if words fail. Cheers Jon
Reply By: ross - Tuesday, Jul 03, 2007 at 18:17
I dont think the H engine has the predrilled mounting holes for the bolts like the 2H.
I cant remember the exact position but I think its down low on the RH side. It does have spot there designed to be drilled.
250546
Reply By: Tony - Tuesday, Jul 03, 2007 at 21:34
For the 2H from memeoy it goes down on the RH side, you need to replace the RH engine mount as it has the mounting point needed. As
well as one on the block.
250606
