Wire sizes- BS to mm2 ect
Submitted: Wednesday, Jul 04, 2007 at 16:59
ThreadID: 47398 Views:6452 Replies:5 FollowUps:5
Hi all,
Does anyone know of a site where there is charts for what wire is equal to what in each diffierent scale, like BS-mm2-amp. Sort of like a Thread chart but for wire. Cheers and beers
Matt
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Jul 04, 2007 at 17:12
Wire Chart
AnswerID: 250731
Reply By: drivesafe - Wednesday, Jul 04, 2007 at 17:54
Hi Matt, the link bellow takes you to a straightforward conversion chart.
The left column is titled AWG but this is exactly the same as B&S.
The fourth column over is the mm2 or the cross sectional area of the copper.
Simple conversion chart
AnswerID: 250737
Follow Up By: drivesafe - Wednesday, Jul 04, 2007 at 18:21
One more point Matt, you need to know what sort of currents you intend to carry in the cable you after and then do some calculations to see just how thick the cable should be to best serve your requirements.
Do not buy any cable just based on the amps marked on the cable.
If cable has amps marked on it, the current is the maximum current the manufacturer recommends but is usually useless for a circuit you are planning to use the cable in.
For example, some 8B&S ( 7.9mm2 ) cable is sold with a 100 amp marking. You could put 100 amps through this cable but if the cable was just 1 metre long and you tried to put 100 amps through it, with an alternator voltage of 14 volts at the supply end, your 100 amp load would be lucky to be getting 9 or 10 volts at the other end.
There’s another link bellow that will save you trying to do the calculations for working out what length and size of cable you will need to best meet your requirements.
Cable Size Calculator
FollowupID: 511895
Follow Up By: Mike Harding - Wednesday, Jul 04, 2007 at 18:29
This whole "automotive" sizing of cables should be totally ditched and all cables described in terms of their cross sectional area as they are in all other areas of electrical engineering. Choosing a cable is a technical judgment which needs to take a number of factors into account, aside from current, and cannot be made on the basis that anyone (including the cable manufacturers) say "it's good for x amps".
Mike Harding
FollowupID: 511896
Follow Up By: Derek from Affordable Batteries & Radiators - Wednesday, Jul 04, 2007 at 18:38
Hi Tim
A good Link it is quite complete thanks.
I have been enjoying your threads on the other forums. Your own forum thread was especially interesting. You should put these cable sizing links on your own website. TRAXIDE.COM.AU
Derek.
FollowupID: 511898
Follow Up By: drivesafe - Wednesday, Jul 04, 2007 at 19:00
Couldn’t agree with you more Mike.
Why the automotive industry here hasn't adapted the European style of metric cabling sizes is beyond me, especially as the all 240 vac cable sizes here have to conform to these sizes and markings.
It would mean one standard, easy to follow, sizing system.
Cheers.
FollowupID: 511908
Reply By: Matt(WA) - Wednesday, Jul 04, 2007 at 19:13
Thanks drivesafe and Derek,
Thats what I was after. I had a 2nd battery installed by a "reputable" aftermarket supplier and I am having drama's with my fridge. The wire they have used to run to the back of my 80 series looks about the same width as single strand speaker cable. So now I will re do it all properly. Thanks for your time and advice.
Matt
AnswerID: 250765
Follow Up By: Mainey (WA) - Sunday, Jul 08, 2007 at 18:22
Matt, what size is the wire, according to the "reputable" aftermarket supplier !!
What length does it run from Battery to Fridge.
FollowupID: 512488
Reply By: Keith_A (Qld) - Thursday, Jul 05, 2007 at 09:25
Hi Matt - you probably already know it, but Collyn Rivers sites may be of interest.
The articles on 'Electrics - Wiring Woes' , Electric Industry standards and 'Refrigeration - 12V wiring' etc.
The site is : Site Link
regards........................Keith
AnswerID: 250863
Reply By: Member - Mike DID - Thursday, Jul 05, 2007 at 20:07
Matt
This table does some calculations for you - it shows wire distances for a 3% voltage drop or less for various currents and wire gauges.
www.freesunpower.com/wires_cables.php
AnswerID: 250942
