removing rear spline from tailshaft
Submitted: Friday, Jul 06, 2007 at 11:33
ThreadID: 47446 Views:2691 Replies:3 FollowUps:2
i want to remove the rear slide shaft from the tail shaft on my gu patrol
i have removed the 4 bolts attaching it to the diff but it wont slide out only moves in and out about 3cm
am i missing something or is there something wrong??
Reply By: Mikee5 (QLD) - Friday, Jul 06, 2007 at 13:07
I am making a guess, but it is probably an air-lock (vacuum) caused by grease in the spline. Try removing the grease nipple to let some air into the joint.
AnswerID: 251052
Reply By: Member - Matt Mu (Perth-WA) - Friday, Jul 06, 2007 at 14:15
Have you unscrewed the retaining collar....It functions as a scraper along the splines and to retain the two pieces together!
Matt.
AnswerID: 251060
Follow Up By: theratt - Friday, Jul 06, 2007 at 17:06
no didnt know there was one must be under the rubber boot seal is it?
FollowupID: 512239
Follow Up By: Member - Matt Mu (Perth-WA) - Friday, Jul 06, 2007 at 18:21
Yep very likely! Slide the boot down and have a squiz and you will find a threaded collar that may take some effort to screw up to the yoke.
All the best
Matt.
FollowupID: 512256
Reply By: disco driver - Friday, Jul 06, 2007 at 17:18
Just another point to remember.
Make sure that you mark all the bits so that you can reassemble them in the same alignment. Failure to do this can result in all sorts of problems. (vibration and excessive Ujoint wear in particular). Otherwise it's a straight forward job.
Disco
AnswerID: 251093
