vehicle in storage
Submitted: Friday, Jul 06, 2007 at 12:15
ThreadID: 47447 Views:1943 Replies:2 FollowUps:3
Hello All,
I have a 1996 80 series pet/gas landcruiser in storage....was just wondering how often i should start it up ?
Also is staring enough or should i take it for a drive...it is registered.
thanks for advice.
Alan.
Reply By: Member - Troll 81 (QLD) - Friday, Jul 06, 2007 at 12:58
How old is your battery? I think once a month should be fine and you do need to drive it otherwise you might get flat spots on your tyres
AnswerID: 251051
Reply By: Mike Harding - Friday, Jul 06, 2007 at 13:13
If possible keep the battery on float charge all the time.
You should start and drive it as often as possible - certainly once a month. It's important to drive it in order to turn the transmission and keep the seals, bearings etc oiled, equally the tyres, suspension, wheel bearings etc need to be exercised.
Don't forget to run the airconditioning for a few minutes too.
People with part-time 4WDs who don't use 4WD often should also find a km of straight road from time-to-time and drive their vehicle in 4WD high (don't turn many corners) for a few minutes to keep the transfer case and front diff oiled.
Mike Harding
AnswerID: 251053
Follow Up By: Mikee5 (QLD) - Friday, Jul 06, 2007 at 13:29
I thing that you mean to do up the hubs but drive in 2H (not 4H), has the same effect and safer. The wheels turn the diff, front shaft & transfer.
FollowupID: 512204
Follow Up By: Mike Harding - Friday, Jul 06, 2007 at 13:33
Good idea and a better way to do it with manual hubs but it won't work if you have auto locking hubs.
A few hundred metres on straight sealed road every month or so won't produce any transmission wind-up worth mentioning I suspect.
Mike Harding
FollowupID: 512205
Follow Up By: Mikee5 (QLD) - Friday, Jul 06, 2007 at 13:36
You are probably right, I am only familiar with my own vehicle which has manual hubs. I agree a few hundred metres in a straight line won't hurt anything either way. Cheers.
FollowupID: 512207
