Terrano II Owners!
Submitted: Saturday, Jul 07, 2007 at 10:15
ThreadID: 47467 Views:3074 Replies:3 FollowUps:1
Just a quick warning to check your jack mounting inside the LHR quarter panel.
We have done quite a lot of High Counry & Outback travel which as you are aware involves a lot of rough work & corrugations.
On our most recent trip to the Outback (June '07), I developed an annoying rattle in the rear, but what's new, the Outback does that!
However, next day, twice the car went into 'limp home' mode for a few seconds & came good after I stopped to check if the loss of power was a flat tyre on the camper trailer, a little later the engine (TD27) started to miss spasmodically, causing more than a little concern due our remoteness. We made camp just on dark & I decided to check the next morning.
Next morning I opted to clean the contents of 3 split cans of Cougar Bourbon & Coke out of the Engel first, after putting it back on it's slide I noticed it wasn't running, more drama!
On tracing back the wiring I found the genuine Engel socket, which I had located in the LHR quarter panel had a smashed positive fuse holder & an exposed wire end.
Luckily the circuit is also fused at the battery & that had blown, obviously just as we pulled in to camp for the night.
Now after all that I will get to the point. What had happened is that the jack mounting plate had torn away from the body & the jack had become the new "rattle in the rear" & had crushed the fridge fuse holder causing intermittent shorting & obviously upsetting the vehicle's computer, causing the erratic engine problems.
There appears to be quite a few Terrano II owners here, maybe we should exchange email addresses & contact each other if we have a problem or need accessories etc. because I have noticed over the years of our ownership, you go in to some places & say 'Terrano II' & they look at you like you have got two heads. Just an idea!
PS. I will pre-empt that some will say that the 3 split cans of Bourbon & Coke was a bigger catastrophy than the engine problems, but I can assure you that when you miles from anywhere & travelling 'single vehicle' engine problems can cause more than a little 'puckering of the valve'
Reply By: Member No 1- Saturday, Jul 07, 2007 at 10:25
i would have sat down, drank the rest, and waited for someone to come and help....me drink em
AnswerID: 251168
Reply By: stevesub - Sunday, Jul 08, 2007 at 10:57
We have a Terrano II (Mistral) as our NZ vehicle for when we are over there (several times a year). It is a 1995 Jap Import and a great vehicle. The specs are slightly different to the OZ ones and does not have the intercooler but does have a 2.7TD engine and auto.
Most of them in NZ are blue in colour and are all Jap Imports - seems strange when 90% of the Terrano II'sl are blue, 9% red and 1% black.
Still we have had 99% reliability over 60,000km with only one power window packing a sad - anyone know where I can get a front passenger power window mechanism cheap?? That is the only problem so far.
There are quite a few being wrecked in NZ now so some wreckers may ship parts to OZ if you want something second hand but the power windows seem to be a common problem and there are not that many around and are very pricey.
My email is stevesub@yahoo.com and if you get in touch with me there, I can give you my real everyday email address.
Steve
AnswerID: 251298
Reply By: hoyks - Sunday, Jul 08, 2007 at 13:14
Ah, the joys of electrickery.
I have run my electrics to the back in some of that split sleave tubing as there were too many sharp edges in the body for my liking. I shed blood running the wires through there, so didn't want to have to do it again.
You have my address already.
AnswerID: 251312
Follow Up By: Shaker - Sunday, Jul 08, 2007 at 14:10
Yes, I thought long & hard before I ran them through there, but I did protect the wires very well, but unfortunately the fuse holder didn't like being hammered by the jack after it tore free from the body!
The jack will now be mounted on the side of the rear drawers, make it easier to get at too.
FollowupID: 512459
