Sun visor for GQ patrol, points closing
Submitted: Saturday, Jul 07, 2007 at 20:47
ThreadID: 47481 Views:5173 Replies:8 FollowUps:5
Hi I wonder if someone could tell me if I can still get an external sunvisor for the front windscreen and where. Also have a problem with the ignition points closing causing the motor to miss the screws do up tight like they should I'm thinking of changing to electronic ignition to solve the problem if it is available for a 1991 4.2 ltr carby motor. I'm very interested in other opinions thanks.
Reply By: honestjohn - Saturday, Jul 07, 2007 at 21:01
hi batt's
i beleive the truck place at rocklea called visor something used to get them from sydney hand made for about $170.00 let me know if you have any luck as i wany one too.
cheers honest john
AnswerID: 251235
Reply By: oldpop - Saturday, Jul 07, 2007 at 21:02
Hi Batt's
RE your points drama put a little bit of high temp grease on the cam in distributor and on the trailing edge of the rubbing block of the points and change them every 20000k set the gap with a dwell meter not feeler guages
regards
Oldpop
AnswerID: 251237
Follow Up By: oldpop - Saturday, Jul 07, 2007 at 21:08
For your Sunvisor try Hy - way Truck Accessories in Sydney
FollowupID: 512376
Reply By: Batt's - Saturday, Jul 07, 2007 at 21:34
I put new points in 4 days ago to see if the previous points where playing up they are only 3 month old and yes I always use grease on the cam shaft Thanks fellers' Ill trya dwell meter mine's a bit dodgy I'll find out about HY-TRUCK Cheers.
AnswerID: 251244
Follow Up By: oldpop - Saturday, Jul 07, 2007 at 21:43
Buy good quality bosch or original there is a lot of rubbish ones out there stay away from chinese ones
FollowupID: 512382
Reply By: Member - Kiwi Kia - Saturday, Jul 07, 2007 at 22:28
If the main sleeve bearing on your distributor shaft is worn you may not be able to properly set your points. Grab hold of the rotor and see if you can detect any wobble in the shaft. Most spare ignition parts come from asia these days so I would not worry about country of origin.
AnswerID: 251254
Reply By: Kev M (NSW) - Sunday, Jul 08, 2007 at 08:59
Batt's
I had a mate get a sun visor for a Maverick from www.hyway.com.au/ and was impressed with the service.
Cheers Kev
Russell Coight:
AnswerID: 251282
Reply By: Batt's - Sunday, Jul 08, 2007 at 15:52
Thanks everyone for your help much appreciated
AnswerID: 251338
Reply By: G.T. - Tuesday, Jul 10, 2007 at 11:09
Be aware that an external sun visor will increase your fuel usage. A timing light will show if your distributor shaft is worn , the light will not hold steady on the timing mark , it will dance around it. Electronic ignition can be the way to go, some are susceptile to high temperatures , it needs to be mounted so it can heat through it`s mounting can dissapate ie - a heat sink is needed. Regards G.T.
AnswerID: 251673
Reply By: Brew34.5(SA) - Tuesday, Jul 10, 2007 at 11:14
Do the electronic ignition conversion. You will never look back. I used the ignitor kit and after 60k its still never needed tuning.
AnswerID: 251674
Follow Up By: Batt's - Tuesday, Jul 10, 2007 at 20:23
The timing mark does dance around I thought the points might have been out a little bit but even after re-checking the points this still happens maybe the shaft is worn. Does this mean the whole dizzy should be replaced 'G.T'. Also 'Brew 34.' I priced elec ignt at Repco $250 they recomend I use a different coil aswell what do you think ,appreciate the previous responces.
FollowupID: 512833
Follow Up By: Brew34.5(SA) - Tuesday, Jul 10, 2007 at 20:32
I never changed the coil on mine. I think i paid $300 or so for mine installed. What brand was the kit? I remember some kits i priced needed a diff coil and thats why i chose the ignitor.
FollowupID: 512836
Follow Up By: Batt's - Tuesday, Jul 10, 2007 at 21:28
I'm not sure what brand he said it went right over my head I'll have to check that one thanks Brew 34.5.
FollowupID: 512850
