AnswerID: 19292 Submitted: Tuesday, May 06, 2003 at 20:36
Member - Martyn
replied:
Sam,
There are some subtle diffrences as I found out when I rebuilt my standard 4.2 diesel when I put a Safari turbo on. The gudgeon pin diameter is bigger in the turbo engine, the top piston ring of the turbo is also reinforced there is also some stronger webbing in the internals of the block of the turbo. Are you taking the engine apart? Depending on the k's you want to have a close look at the cylinder head for cracks, and when you put the head back on used the thickest head gasket available. I also installed a thermocouple on the exhaust outlet of the turbo not the best place but it gves good indication, I don't run the gasses any hotter than 450 degrees C without changing down a cog. You can go higher but it very much depends on where you are reading the temp to be safe. Don't let anybody kid you about the radiator, with a three core with air con I found the engine ran hotter, I reverted back to the original 2 core radiator and it works a treat. If you have the big Nissan badge on the front grille this reduces air flow by 17% on it's own without extra lights, you need to remove it. Hope some of this helps. Keep the shiny side up
Reply 4 of 4
