$350 gennies
Submitted: Tuesday, May 06, 2003 at 10:00
Tony from Helton Heat Exchangers
I have been watching the threads on these units and they are truly value for money. Helton are now offering them from our
brisbane store for $385 (exploreoz members $350 with your disc) should be on the store soon or contact us 0428118012.
mod et 950 600W cont 800W peak
www.helton.com.au ( pic on accessorries page)Helton Heat Exchangers
Reply By: Cobes - Tuesday, May 06, 2003 at 10:25
Tony,
Do these gene's offer 12 volt output and 240 at the same time?
Or can you only use one outlet at a time?
Chris.
19240
Follow Up By: Tony from Helton Heat Exchangers - Tuesday, May 06, 2003 at 11:20
Chris
Yes , providing you are not drawing above 600 W at 240 v
TonyHelton Heat Exchangers
12074
Reply By: diamond - Tuesday, May 06, 2003 at 13:32
gday tony loved that heat exchanger at
easter.the gennie i put the thread up about run 850 continious and 950 peak had no troube running 850 watt angle grinder for about 1hr.
19253
Follow Up By: Tony from Helton Heat Exchangers - Tuesday, May 06, 2003 at 15:03
Hello Diamond
I'll bet the missus was happy too!! I had
mine working hard to and all were suitably refreshed. the kids who were crawling around the boat with yesterdays bait were also much nicer to be around.
I'm not sure if the gennies are the same ? could ya have a look at the pic on my site and let me know (accessories page)
sounds like your model is a better buy for the output
I have a friend importing ROC equipment and most is very good and the price makes this gear available to a larger group who could not spend $1200 odd for the same thing
12089
Reply By: Member -BJ (Sydney) - Tuesday, May 06, 2003 at 16:56
I presume gennie would to charge camper batterie. You site said it was quite , as quite as the honda 10ei.
BobWish i was still here / Gulf in July
19276
Follow Up By: athol - Tuesday, May 06, 2003 at 17:35
Just bought one from the show at Rosehill the guy said the 12v supply is unregulated at 10 amp so you will have to be carefull when charging you don't
cook the battery. Haven't had a chance to use it yet !!!!!
12099
Follow Up By: diamond - Tuesday, May 06, 2003 at 17:56
my chineeses gennie says 14.4 volts @9amps does that mean it will only charge to 14.4 volts?
12102
Reply By: diamond - Tuesday, May 06, 2003 at 19:04
gday tony.i looked at the pic you have on your site it looks identical to my one it must be the little brother.the mrs loves the hot showers we can all have now.no more dirty weekends(thanks mate).
19285
