timing belt light.
Submitted: Tuesday, Jul 10, 2007 at 14:37
ThreadID: 47577 Views:4690 Replies:6 FollowUps:2
anyone know how to get the timing belt light to turn off on a hzj79 2001 model?. digital dash
Reply By: Ingtar - Tuesday, Jul 10, 2007 at 15:11
I have a 2000 model 100 series... I have been told there is a tiny hole in the dash somewhere. Behind this you can see a button. I believe you poke it with a bit of wire/paperclip or something?
AnswerID: 251707
Reply By: Member - Tour Boy- Tuesday, Jul 10, 2007 at 15:12
Is there a reset plug like the old ones. If not probably by laptop.
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 251708
Reply By: Time - Tuesday, Jul 10, 2007 at 15:15
Look at post 20993
AnswerID: 251709
Reply By: Wayne-o (Pilbara WA) - Tuesday, Jul 10, 2007 at 16:30
disconnect and reconnect all batteries worked on the hilux surf!
AnswerID: 251718
Follow Up By: jeffwa - Tuesday, Jul 10, 2007 at 18:24
I just used a paper clip of my surf and pushed through the little hole in the instrument cluster.
FollowupID: 512813
Reply By: Mikee5 (QLD) - Tuesday, Jul 10, 2007 at 18:40
Here is what I got from the LCOOL website for the 100 Series. Hope it helps!
Quoted below:
1. T-BELT MODE DISPLAY
a) With ignition turned ON, using the trip switch (select/reset button) change the display to ODO, and turn the ignition OFF
b) While pressing the trip switch, turn the ignition switch ON and hold it for 5 seconds.
c) Release the trip switch, then press the switch again within 5 seconds.
d) The digital display should change to T-belt mode. The initial display "15" (0,000km) is displayed (ie. 150,000km).
2. REWRITING REPLACEMENT VALUES
While in the T-Belt mode, each press of the trip switch will change the displayed value by 10,000km increments. Once " 20 " (200,000km) is reached the display reverts back to " 1 " (10,000km) again. Remember, this setting is the number of kilometres to be travelled before the light comes on next, and once reset this counter will start from zero.
I believe the timing belt interval for all the 100 series engine variants is 150,000km, but this should be checked against each different markets servicing recommendation. This being the case, you shouldn't need to change from the default setting of "15".
Obviously for the US, the ODO is in miles, and I guess the T-Belt warning would be set in 10,000 mile intervals.
3. T-BELT WARNING RESET COMPLETION
a) After setting the replacement setting value, hold the trip switch ON for more than 5 seconds then release the switch.
b) Check that the display has now changed back to ODO and that the warning light has gone off when the engine is started.
NOTE: If the T-Belt mode is completed, even though the belt replacement has not been performed, the T-Belt warning IS reset.
I hope this proves to be of assistance guys, as usual all care no responsibility. ;-)
AnswerID: 251745
Reply By: Member - Phil G (SA) - Tuesday, Jul 10, 2007 at 18:42
Time got it right.
All the rest is witchcraft
Original link for resetting digital timing belt warning light
AnswerID: 251746
Follow Up By: Member - Phil G (SA) - Tuesday, Jul 10, 2007 at 19:33
Mike beat me by 2 minutes :-)))
FollowupID: 512826
