GQ door hinges
Submitted: Tuesday, Jul 10, 2007 at 19:21
ThreadID: 47591 Views:2742 Replies:2 FollowUps:4
I have just purchased some after market hinges from ebay as both the front doors are in need of replacement. Has anyone changed theirs and if so was it an easy job to do? I'm no mechanic but give most things a go so i'm hoping this is an easy job to do.
Reply By: nowimnumberone - Tuesday, Jul 10, 2007 at 21:33
gday brewster
i did some today not to bad a job
easy if theres two of you
loosen all the bolts on the door side a little remove one from the top and the bo9ttom completely
then with some one holding the door remove the others and move door to somewhere safe
\unbolt hinges fron pillar and fit new ones
try to align them with the old paint marks and tighten
lift the door back and semi tighten all bolts trying to align old spot
close the door to make sure it all aligns up
bobs your uncle
AnswerID: 251798
Follow Up By: Brew34.5(SA) - Tuesday, Jul 10, 2007 at 21:37
Cheers mate, will see how i go. Did you fit the genuine ones?
FollowupID: 512853
Follow Up By: Brew34.5(SA) - Sunday, Jul 15, 2007 at 20:32
Ok here's how it went. Started Sat morning 11am.
Got 12mm spanner and socket ready. Much cursing and swearing as the lack of room for a man with hands the size of mine proved to be a challenge. Door removed :)
Removed old hinges.(holy sh1t..........how are you supposed to get a spanner in there lol.)
Installed new hinges in marked area. Got my lovely wife to hold the door whilst i bolted it back on.( i recommend not using the wife for this as divorce could become a reality lol) Test time........GRRRRRR Door about an inch too high.
Whilst removing the door again the ratchet on socket lets go and i smash my thumb nail into the hinge and i shout obsenities that people in Victoria would hear.(the dog and the wife decide now is a good time to disappear)
Adjust hinges and bolt door on for the second time. GRRRRRRR door is too low
now.
Remove the door again in such a rage that my neighbour comes over to investigate. He makes a few suggestions and the door goes back on and wow this time is closes albeit still a bit too high but its 4 o'clock now lol so i give up and wait until sunday. The door is also too far back as the rear door cannott be opened lol.
Sunday morning...........remove door and adjust hinges again. BINGO just like a new one and it only took half an hour lol.
Next weekend i can attempt the passenger door lol.
Almost as easy as you mate lol. And my thumb is still sore :((
FollowupID: 513658
Reply By: Batt's - Thursday, Jul 12, 2007 at 22:31
Hey Brew when I open the drivers door on my GQ you can lift it up and see the hinge pin move a fair bit. How much did you pay for yours, who did you get them from. thanks.
AnswerID: 252138
Follow Up By: Brew34.5(SA) - Friday, Jul 13, 2007 at 07:46
here
FollowupID: 513223
Follow Up By: Brew34.5(SA) - Friday, Jul 13, 2007 at 07:48
If you only want one set look in his ebay shop.
FollowupID: 513224
