Caravan Brakes
Submitted: Wednesday, Jul 11, 2007 at 08:44
ThreadID: 47605 Views:4465 Replies:2 FollowUps:1
Good Morning , I am looking for information on the correct way to adjust the caravan brakes. When adjusting the tandem caravan brakes to suit a tekonsha controller, do I adjust the ratchets up as normal or back-off 6 or 7 clicks to suit this brake controller?
Which is correct ,over to the forum.
Thanks , Brush
Reply By: The Fox - Wednesday, Jul 11, 2007 at 08:53
From the instruction sheet on the Tekonsha website:
Appendix A: Trailer Brake Adjustment**
Brakes should be adjusted (1) after the first 200 miles
of operation when the brake shoes and drums have
“seated,” (2) at 3000 mile intervals, (3) or as use and
performance requires. The brakes should be adjusted
in the following manner:
1. Jack up trailer and secure on adequate capacity
jack stands. Follow trailer manufacturers recommendations
for lifting and supporting the unit.
Check that the wheel and drum rotate freely.
WARNING Do not lift or support trailer on
any part of the axle or the suspension system.
2. Remove the adjusting hole cover from the
adjusting slot on the bottom of the brake
backing plate.
3. With a screwdriver or standard adjusting tool,
rotate the starwheel of the adjuster assembly to
expand the brake shoes. Adjust the brake shoes
out until the pressure of the linings against the
drum makes the wheel very difficult to turn.
Note:With drop spindle axles, a modified adjusting
tool with about an 80 degree angle should be used.
4. Then rotate the starwheel in the opposite
direction until the wheel turns freely with
a slight lining drag.
5. Replace the adjusting hole cover and lower
the wheel to the ground.
6. Repeat the above procedure on all brakes.
WARNING Never crawl under your
trailer unless it is resting on properly
placed jack stands.
Follow the trailer manufacturers recommendations
for lifting and supporting the unit. Do not lift or place
supports on any part of the suspension system.
**Note: Trailer Brake Adjustment procedures
courtesy Dexter Axle.
AnswerID: 251852
Follow Up By: Brush - Wednesday, Jul 11, 2007 at 11:55
The FOX, thanks Mate , I just keep doing the same old tried and proven way of adjusting the brakes. Cheers Brush.
FollowupID: 512944
Reply By: Mick - Wednesday, Jul 11, 2007 at 22:37
oh boy!!
AnswerID: 251992
