Oxygen Sensor location on 4.5L 'Cruiser
Submitted: Wednesday, Jul 11, 2007 at 09:22
Hatcher
I suspect my O2 sensor on my 100 Series is dodgy, but I can't locate it. A friend has an 80 Series with the same 4.5L engine and we can't find it on that either. Do any 'Cruiser owners or mechanics know exactly where it hides? Thanks.
Reply By: Rod W - Wednesday, Jul 11, 2007 at 10:00
Just curious to know what makes you suspect its dodgy?
251864
Follow Up By: Hatcher - Wednesday, Jul 11, 2007 at 10:37
Fuel consumption has been slowly increasing over the past 12 months. I drive the same route every day and fill up at the same Shell servo. Used to get 300km on 45L. Now only get around 270km. Had a mechanic check it out and he replaced fuel and air filters which didn't fix it. I have read on the net that a crook O2 sensor can cause this problem but most mechanics change it without testing it first. Thought I would test it myself before forking out $150+ for something I might not need.
512936
Follow Up By: Rod W - Wednesday, Jul 11, 2007 at 10:56
I think you'll find it in the exhaust system
512938
Follow Up By: Hatcher - Wednesday, Jul 11, 2007 at 12:01
Looked from the exhaust manifold down to the tail pipe, couldn't find anything with a wire on it. I haven't removed the heat shields on the manifold to see under it, but a can't see any wires leading from it so I don't think it's there. Besides, the "Cruiser has a split manifold that merges into one exhaust pipe so I would expect the sensor to be after the branch so as only one sensor would be required.
512945
Reply By: landseka - Wednesday, Jul 11, 2007 at 13:40
As far as I know (on the 80series anyway) it is in the air intake right next to the air cleaner.
I've never had
mine off but I believe they can be cleaned. Apparently they just have thin wires crossing the airflow. The wires can get gunked up with oil residue fumes that enter the a/c from the engine breather.
Hope this helps
Neil.
251888
Follow Up By: landseka - Thursday, Jul 12, 2007 at 19:14
I told fibs here...this is the Airflow Meter, the O2 sensor is on the inner guard just near the windscreen washer bottle.
513166
Reply By: Member - Phil G (SA) - Wednesday, Jul 11, 2007 at 14:00
Best of luck finding one on the 100series - they don't have one :-))
The 80series 4.5 did though, so your friend can keep looking!
251889
Follow Up By: Hatcher - Monday, Aug 13, 2007 at 14:51
Hi Phil,
You seem to know a bit about Cruisers. I have almost rectified my Cruiser's drinking problem. I disconnected the battery for a few minutes to allow the ECU to reset itself. I'm almost back to normal fuel consumption and it's more responsive. I'm guessing the knock sensors had severely retarded the timing. (little tip for everyone). However, the idle speed is too high (820 rpm) due to the mechanic adjusting idle without first resetting ECU.I think idle should be about 650rpm. I cannot find an idle adjustment screw anywhere. Do you know if idle can be adjusted without the use of computers? 2000 model 1FZ-FE. Also, I can't find a MAF sensor on the beast either. On my friends 80 it's on the air intake, but not present on the 100. Thanks.
518195
Reply By: Sibe - Wednesday, Jul 11, 2007 at 14:19
I'm not incredibly mechanically minded myself, but as a recent purchase has included me in the catergory of 4.5L 80 series owners, i too find the mileage on the vehicle incredibly low. I'm getting around 6 km's per litre on Standard Unleaded. (Which i note is similar to your mileage of 270kms off 45 litres) Have used Premium ULP in the current
tank to see if this improves the mileage, but yet to refill to see the difference.
Any other 80 series owners got some feedback on weather this is normal mileage for these vehicles or should it be better than that? My vehicle is extremely stock standard (for now!!) so it's only going to get worse under load. I haven't really started looking into ways to improve this yet...any suggestions are appreciated.
Sibe
251893
Follow Up By: madfisher - Wednesday, Jul 11, 2007 at 21:51
Can take up to 5 tanks of premium for the computer to reset its self on some vehicles, not sure about 4.5 though
Cheers Pete
513035
Reply By: landseka - Wednesday, Jul 11, 2007 at 15:06
Hi Sibe,
I get very similar mileage out of my 4.5 as you are getting, down to 4 - 4.5 kml when towing my 16' caravan.
I improved my traveling expense by fitting a LPG conversion courtesy of the state (wa) and federal govt so it cost me nothing to install.
I now get around 5kpl & 3kpl respectively on gas with very little (if any) noticeable power loss.
At over half the cost of ulp this amounts to huge dollar savings on a trip.
Neil.
251895
Reply By: Member - Brian A (QLD) - Wednesday, Jul 11, 2007 at 17:30
I have had my 1995 80 series (Auto) for over 10 years and the fuel consumption has remained fairly consistent at 16l per 100km and about 20l per 100km when towing our loaded Ultimate camper trailer.
Hope this helps.
Brian
251911
Reply By: Andrew-rodeo - Wednesday, Jul 11, 2007 at 18:39
They don't all have them.
251937
