Navara Diesel Engine warning light
Submitted: Wednesday, Jul 11, 2007 at 13:13
ThreadID: 47617 Views:3460 Replies:5 FollowUps:2
In travelling up the top end of oz, on the corrugated roads, my engine warning light has come on many times. Sometimes I get a flat spot below 2k revs.
The manual suggests it is either water in the fuel filter or a MAJOR problem. I have bled the fuel filter, (mostly air??), then it is alright for a couple huindred k's?
Any ideas?
Brian
Reply By: Notso - Wednesday, Jul 11, 2007 at 13:37
Sounds like you have a recurring fault in the engine management system.
You should go to a dealer and get them to run the diagnostics over it.
Could be any one of a number of sensors giving the fault.
It could also be a faulty earth connection somewhere.
Which engine is it. The 3.00 or the 2.5
AnswerID: 251886
Follow Up By: vcbb - Wednesday, Jul 11, 2007 at 13:41
3 litre TD
All goes well after I bleed the filter, if I dont do that the problem gets worse, which why my thoughts were more to do with the actual filter and the bumpy roads?
FollowupID: 512954
Reply By: geoff&Mandy - Wednesday, Jul 11, 2007 at 14:04
sounds like a blocked fuel filter 2 me try changing it
AnswerID: 251890
Reply By: jeffwa - Wednesday, Jul 11, 2007 at 14:16
ZD30 Engine light and loss of power under 2k sounds like EGR vavle to me. Was a common problem with the 3.0L patrols... Don't those Nissans have a water trap/fuel light on the dash?? Even a mitsubishi express diesel's got one of them along with the standard issue AM radio!
AnswerID: 251892
Reply By: Member - Lance S (VIC) - Wednesday, Jul 11, 2007 at 14:25
vccb
You shouldn't be getting air from the fuel filter when bleeding the filter. Disconnect the wiring plug from the fuel filter and see if the engine light comes on. You could have one of many problems with sucking in air from,
a crack in the fuel filter housing,
loose hose clamp on fuel line
a pin hole in the fuel line
blocked fuel fitler
"o" ring on the bottom of fuel filter
After checking these things and it hasn't improved i would replace the fuel line
from tank to filter.
cheers, Lance
Home Away from Home
AnswerID: 251894
Reply By: Member - extfilm (NSW) - Wednesday, Jul 11, 2007 at 18:47
vcbb,
How long ago was the filter changed? When I got my first filter I was also given a seal about the size of a 10 cent piece. Was told by Nissan it must be fitted whilst screwing on the filter or it will suck air??????
I did what I was told and have not had a prob with the fuel system.
AnswerID: 251941
Follow Up By: On Patrol (Aust.) - Wednesday, Jul 11, 2007 at 19:20
vcbb & extfilm, My bet is
Yes air in the fuel, but could be from air sucking in from the fuel lines. I had a similar issue with my Patrol on my Cape trip. I replaced all the clamps on my fuel lines and no more problem.
Colin
FollowupID: 512992
