Mounting fridge slide in 80 series
Submitted: Wednesday, Jul 11, 2007 at 17:32
93 Navara
Have read a few posts in relation to mounting a slide in the rear of an 80 but still haven't found what I'm after. Seems some mount their slide to ply and cut that to fit the rear of their car. I'm hoping to avoid that and mount it directly to the floor, hopefully without having to move the sub
tank. Any advice please.
ps Want to avoid putting drawers in so I can sleep in the back
Reply By: Matt(WA) - Wednesday, Jul 11, 2007 at 17:49
Have a look in my rig pictures. I made my own slide up which I am sure you could design to bolt into the mounting holes in the floor of an 80 (for tire downs povo pack or rear seats glx). Even if you need to teck screw them into the floor there is a fair gap between the floor and the subtank. As long as you dont use three inch teck screws you should be right.
Matt
251916
Reply By: 93 Navara - Wednesday, Jul 11, 2007 at 18:03
Haven't lifted the carpet but don't the rear seats mount to the side?
251919
Follow Up By: Matt(WA) - Wednesday, Jul 11, 2007 at 18:14
Dont know mate as I have the pov pack but the instructions for mountind my drawers said they were there? Not sure though
Matt
512980
Follow Up By: Max - Sydney - Wednesday, Jul 11, 2007 at 19:23
Mate - the little seats mount off the side, but the bar things that the seats lock onto are held down by two bolts that you can use, and when you lift the carpet, you will find a couple of other welded nuts to tie down to (I think two of the tie downs). The drawers from the mob in
Cairns use them and have held tight for 10 years on
mine.
Max
512994
Follow Up By: Member - Karl - Thursday, Jul 12, 2007 at 09:53
I used the same bolts when I made my dodgy drawers :-)) for my 80 series. There are four set of two bolts for the seats and four tie down points as
well in the GXL, but I am not sure what the standard has - should have the tie down points as a minimum.
Lift the carpet and see what tie down points etc you have and then use them.
Karl
513089
Reply By: Kev M (NSW) - Wednesday, Jul 11, 2007 at 18:06
Use the child restraint bolt holes as
well as the ones for the rear seats.
Cheers Kev
| Russell Coight:
251920
Follow Up By: Axel [ the real one ] - Wednesday, Jul 11, 2007 at 19:10
Child restraint captive nuts in the GXL 80series are in the roof , ,
512988
Follow Up By: Max - Sydney - Wednesday, Jul 11, 2007 at 19:26
There are child restraint captive nuts on the floor too, but you don't need them for the drawers. I still have the restraints in, and use them via a couple of cunningly concealed openings in the slide and the shelf over the one drawer I have. All by design.
Max
512997
Reply By: Hairy - Wednesday, Jul 11, 2007 at 20:14
Be careful!
The right hand rear corner fixing point of your slide ( if positioning on the right hand side) does NOT! have a lot of room between your floor and sub
tank as stated above. I originally fitted
mine temporarily with tek screws ( no they werent long) and speared one right through my sub
tank. I would not rely on tek screws and plan on taking out my subtank so I can fit it properly using body washers and/or welding nuts underneath. A bolt with a hook on it would make a better temporary fixing.
251954
Reply By: Member - Debbie R (SA) - Wednesday, Jul 11, 2007 at 21:13
I have recently purchased another 80 series, 1991 deisel with an after market turbo fitted (an essential by the way). The vehicle had a drawer system fitted, I cut a section out of the top of the system the length and width of my fridge, added tie down points to the base of the drawer, and there you have it, a ready made fridge slide inside the drawer. I still have 1 drawer and the fridge is the right height to use comfortably with some room inthe drawer behind the fridge.
Good luck with it.
Barry and Debbie
251967
Reply By: 93 Navara - Wednesday, Jul 11, 2007 at 22:04
Many thanks to all that replied. I'll lift the carpet tomorrow and have a good look. All being
well I'll fit it later this week
251979
