Oil
Submitted: Thursday, Jul 12, 2007 at 15:10
ThreadID: 47653 Views:12063 Replies:13 FollowUps:27
Hi all
Had a service done on my Series 80 (240K) and the mechanic told me I should consider using Penrite Oil. I have been using RX Super in the vehicle since I purchased it with 30K on the clock.
Any thoughts or suggestions why he would ask this? When I asked him he stated that as the vehicle gets older a better quality oil should be used. (??)
From memory I think Toyota recommended this oil to me.
Howard
Reply By: MEMBER - Darian (SA) - Thursday, Jul 12, 2007 at 15:31
Better quality ? Is he a lubrication industry engineer ? Who says the Penrite is better ? The man wanting to sell it of course !! As you have quoted him, that's nothing more than sales orientated babble. Maybe his $ margin on Penrite oils is better ? If he had a techically sound basis for his suggestion, that might be different............
AnswerID: 252065
Reply By: Brew34.5(SA) - Thursday, Jul 12, 2007 at 15:51
That's interesting. I had my GQ at a diesel specialist last week to check on a couple of things and i asked them what oil they used and they told me Penrite. I told them i was using RX Super as the previous owner had always used it. Their suggestion was to not use RX Super which is 15 40. Because i have an older car i should be using 15 50 or even 20 60. They told me not to buy it from them but anywhere i could get it. Must be good stuff if it's being used by a Diesel workshop.( I won't name the place on here)
AnswerID: 252066
Follow Up By: jeffwa - Friday, Jul 13, 2007 at 11:25
I was using Penrite Jap Truck 15w40 oil and had no problems other than a small amount of blow by which I think is normal for a turbo diesel at about 200,000ks. I changed to 20w-60 penrite and got awlful blow by and even a film of oil around the thorrle body. Switch back to 15w40 and it settled down again. Just recently I changed to Castrol Diesel Magnatec 15w40 and I have no blow by at all, I even tested this by removing the turbo inlet pipe and cleaning it, it is still clean. I have no film around the throttle body and no mess on the rocker cover... Just food for thought. My engine is a 3.0L TD 1kz-te Toyota.
FollowupID: 513264
Reply By: KSV- Thursday, Jul 12, 2007 at 15:54
AFAIK oil brand is not so relative as oil thickness (to certain extend, of course – I am not talking about cheap no-brand stuff). Older vehicle would require thicker oil – it is for sure. You have not say, BTW, is yours diesel or petrol. I am using Penrite oil on my diesel LC for 7 or so years and definitely can recommend it. But saying this I would not dispute that, say, Mobil or Castrol as good as. Main criteria thickness.
AnswerID: 252067
Reply By: Member - Phil G (SA) - Thursday, Jul 12, 2007 at 16:12
Oils are oils................Penrite is no different to any other brand with the same specs.
To use thicker oil is a sure way to accelerate wear. It takes longer for oil to get around at startup.
AnswerID: 252068
Follow Up By: KSV- Thursday, Jul 12, 2007 at 20:13
Strangest POV. Thicker oil (to certain extend of course) is better lubricant and therefore will prolong engine life. We always talking about compromises here. Sure thicker oil will require more warm-up then thinner one. So if put too much load on cold (particularly sub-zero) engine with thick oil then oil pressure will go too high and could lead to damage. But if one has no brain in skull, what can I say? Plus manufacturers trying to specify as thin oil as only possible, because it lead to less fuel consumption. Thinner oil however (I am talking here about mineral and semi-synthetic oil, have not got much experience with fully synthetic one) worn out much faster and therefore will require changing more frequently. And in addition if engine already a bit worn out, then putting thicker oil will definitely improve torque. And of course if oil too thin then there will be just not enough pressure to lubricate properly in hot condition under high load. Anyway they always recommend to put thicker oil (engine as well as transmission) when driving in hard condition – I would be interested how it is coexist with your theory?
FollowupID: 513177
Follow Up By: Member - Phil G (SA) - Thursday, Jul 12, 2007 at 20:52
KSV, Can I ask you to cut and paste what you've written above, and email it to every major oil company and see how they respond.
Perhaps you can put some gear oil into your engine and see how it goes.
FollowupID: 513187
Follow Up By: Member No 1- Friday, Jul 13, 2007 at 07:45
"Oils are oils"...????
i'm gunna tell Sol what you said...i reckon he aint gunna be happy
FollowupID: 513222
Follow Up By: KSV- Friday, Jul 13, 2007 at 08:04
==>Perhaps you can put some gear oil into your engine and see how it goes.
They says “Ask fool to pray and he sure smash his head against floor”. What can I add?
As for oils companies they love me to put thinner oil in my engine because that means more frequent oil change and more profit for them. Furthermore they start to convince me that I would beneficial enormously by putting fully synthetic $25/l oil into 20 y.o. commodore. Why? Again because they can make more money.
You missed key words “to certain extend of course”. FYI am using Penrite HRPDiesel 15 with 15W50 rating. Penrite, however, recommends HRP Diesel for Toyota 80 series and this is **THICKEST** diesel oil what they produce. I am happy to use a bit thinner for two reason – I have DTS turbo and change oil at 7.5K interval. When I will be going to desert, I would definitely consider thicker one.
This is extraction from Penrite site:
HPR DIESEL
High viscosity engine oil for use in older diesel engined vehicles operating in extreme climates, under high loads or where oil consumption with conventional viscosity grades is a problem. May be used in turbocharged engines.
SAE 20W-60, API CH-4/SJ, ACEA A3/B3, M2C 911-A1, Global DLD-1
Key words here “High viscosity” and “under high loads”.
You really have to do your homework better before posting such misleading information.
FollowupID: 513225
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Jul 13, 2007 at 09:14
KSV aren't you an insulting little prig. To wit "They says “Ask fool to pray and he sure smash his head against floor”. What can I add?"
FollowupID: 513238
Follow Up By: KSV- Friday, Jul 13, 2007 at 09:18
Probably :-) But he suggest me to use gear oil in engine :-)
Little (i.e. young)? Oh, I wish :-)
Cheers.
FollowupID: 513241
Follow Up By: Member - Phil G (SA) - Friday, Jul 13, 2007 at 09:51
KSV,
You sound very passionate about thick oil! I'll go back to my original statement.
"To use thicker oil is a sure way to accelerate wear. It takes longer for oil to get around at startup."
I used the word "Thicker". By that I mean thicker (higher viscosity) oil than is specified for the vehicle. Penrite 20W60 for example is a thicker oil than most manufacturers specify for temperatures in most of Australia.
You may have noticed that manufacturers are using thinner oils. Most petrol vehicles are now using 5W30 and many newer diesels have dropped to this viscosity as well. The primary reason is to reduce wear, the secondary reason is better fuel consumption.
So how does thinner oil reduce wear??? Its all about getting everything lubricated as quickly as possible at startup, and in particular, the overhead camshaft and components on the top of the engine. The majority of wear happens at startup - so its one reason why a diesel that does short trips will wear out quicker than a diesel that does the long runs.
Vehicle manufacturers have progressively reduced the size of the oil galleries, so they need less oil to fill them, and they have are also making oil filters smaller, so they fill up quicker. FLOW is the keywiord here. A thinner oil flows better than a thick oil, so it travels more quickly down a thin tube. So the end result is that the top end of the motor is lubricated sooner, and with thinner oil (like when the motor is hot) so it flows better.
Your Penrite quote is fine, but I think you have picked the wrong key words. You said the key words were "high Viscosity" and "under high loads". I'd suggest the most important key words in the statement is "older diesel", "extreme climate" and "where oil consumption with conventional viscosity grades is a problem". In real life, we may be talking about less than 1% of users.
I do my homework.
FollowupID: 513251
Follow Up By: Member - Phil G (SA) - Friday, Jul 13, 2007 at 10:07
I've learnt to ignore the abuse that KSV hurls to many posters on this forum, so I just ignore it.
As for Member No1, yep you've got me worried - Sol looked pretty mean, but I liked his set of wheels.........
FollowupID: 513252
Follow Up By: KSV- Friday, Jul 13, 2007 at 10:45
I am sorry, Phil, but your statement “using thicker oil wear of engine because of start-up process” is as much absurd as saying “difflockers is best way to kill your driveterrain faster because it put extra stress when cornering”. I mean – use everything **PROPERLY**. If one fill engine with thicker oil and then start it in winter in alpine at –10 degrees and then immediately tows huge caravan uphill – sure method to kill engine. In the same way if one lock diffs and will try cornering at 100 km/h on freeway – sure recipe for disaster. I been using 30W70 in my old 60 series Cruiser for years including subzero alpine situation and yet sold it in perfect condition. Key word here – I never drive hard until engine get worm enough. Manufacturer doing lots of silly things trying to make their cars bullet-proof purely because average buyer plainly stupid to take care of his/her car properly. For example in average they probably have more problem if people stupidly drive too hard cold engine with thick oil in it. At the same time manufactures have very little problem with premature wearing using thin oil. And what “premature” means here? 300K instead of 400K? But they do not care because it very much off warranty anyway! And we discussing exactly 300k v 400k here – new vehicles can use whatever as long as it in accordance with manufacture recommendation.
As for abuse, I like kindly pointed you that you first start to insult me suggesting to use gearbox oil in engine. Before this point I just state that I **PERSONALLY** found your POV strange – no more, no less. Or probably your definition of abusing differs dramatically depending if a person a member or not? Then I really start to wonder if I ever should became a member.
I do not like to continue this discussion – Penrite and I thinking in the same way and therefore I can easy by-pass your wisdom.
Regards and have a good Black Friday.
FollowupID: 513257
Follow Up By: KSV- Friday, Jul 13, 2007 at 10:47
Sorry, no editing. OP was questioning about 240K car. IMHO old enough to be considered "older diesel"
FollowupID: 513258
Follow Up By: Member - Hughesy (NSW) - Friday, Jul 13, 2007 at 20:29
Hi, Don't want to continue this debate too much but the comments about needing a thicker oil for "high loads" and "extreme conditions" isn't a necessity. All our heavy mining equipment runs on Castrol RX Super and these engines run at maximum HP, maximum revs and in stinking hot conditions for probably 70% of their total running time. Driving across the Simpson desert is not "extreme conditions" and your engine is hardly under "high loads" for more than probably 20% of the time. Most of heavy equip engines will get 15,000hrs between rebuilds (thats more than all but the oldest and most driven vehicles wil ever do).
Not saying that using the Penrite 20-60 is bad - I used to use it in my old TD Rodeo before I learnt more about diesel maint and care from working in the mining industry. I'm with Phil - a thinner (recommended oil) oil is better for all but the oldest and most worn engines that need thicker oil to hold oil pressure.
FollowupID: 513350
Reply By: Member - Oldplodder (QLD) - Thursday, Jul 12, 2007 at 16:19
I have been using Penrite since new, well after the engine had done 40K. Now done 290k. Have had no problems and all seems well.
There are now three penrite diesel oils.
The old penrite diesel - HPR diesel - 20w/60 and a new penrite deisel - HPR 15 - 20w/50. I think I would go for that one. There is also the HPR 5 - 10w/40. The HPR 5 & 15 are semi synthetic.
Have had friends use penrite diesel in pajeros and have problems. But they were doing the filter every 10,000k, and oil every 5000k, as recommended by Mitsu, where as I do filter and oil every 5000. I think the penrite has a reasonably high detergent content, and the filters were going to bypass and not cleaning the oil before the 10,000k were up. Galleries were getting blocked.
Slightly heavier oil may reduce consumption. Are you putting in any oil between changes now? Maybe this is what they are thinking off.
Yes, penrite is more expensive.
AnswerID: 252071
Follow Up By: Member - Howard T (QLD) - Tuesday, Jul 17, 2007 at 09:45
Thanks for the replies.
Not using any oil between changes. They are done religiously every 5000K along with the filter.
Maybe I just stick with the RX Super.
HowardT
FollowupID: 513973
Reply By: Member - Mark E (VIC) - Thursday, Jul 12, 2007 at 18:52
Howard,
There is a great deal of information on engine oils on the following website:
www.lcool.org/
I have a 1HZ 105 series and went through the same process trying to find out what the best oils for this engine was, given that I will most likely have to hold on the the thing for the term of my natural life.....
Consensus was that given the differing requirements of european, american and japanese engines that an oil that has an additive package suited to japanes diesel engines would be the most suitable. The only ones I know of (there may be others) are Castrol J-Max and Caltex CXJ. You would mot likely find the majority of lcool 'diesel-heads' would be using those oils and it is what I use.
Whether or not it will make any difference in the long run....??? who knows. The only thing I know is that people with a VAST amount of knowledge about oils came up with this, so unless someone else with even greater knowledge can convince me otherwise, I will stick to this.
Sorry Phil, even with the amount of reading I've done on oils, I would have to respectfully disagree with you......."oils aint oils, Sol"....!!!! I would commend you to do a Google search on the big end bearing failures on the earlier Turbo 80 series engines (can't remember the nomenclature)....from what I read, it was largely attributed to the type of oils run in the engines. Something to do with the calcium percentage contained in various oil additive packages.
Hope this doesn't create too much more confusion.
Again, just my .02c
Mark
AnswerID: 252100
Follow Up By: Member - Phil G (SA) - Thursday, Jul 12, 2007 at 19:41
Mark,
They are all interesting and logical arguments, and with all this oil talk, theres rarely a wrong answer. Lets face it, its pretty hard to wear out the rings on a 1Hz if its regularly serviced with any diesel engine oil.
But Toyota recommend an API spec oil CD, CE, CF-4 and above, not a Jap spec oil.
Castrol recommend 7 different oils for the 1Hz and J-max is not one of them.
Caltex recommend 2 oils for the 1Hz and CXJ is not one of them.
So I go with what a famous LCOOLer (Norm Needham) has always said, and that is that any diesel oil of the Toyota recommended spec will do.
FollowupID: 513169
Follow Up By: Member - Mark E (VIC) - Thursday, Jul 12, 2007 at 23:02
Phil,
A sense of de-ja-vu here I think? I feel that we have had this debate once before.
I have several friends with Toyota diesels (mainly 1HZ) many of whom use the cheapest (reasonable) oil they can get...none of them have blown up to my knowledge. I guess I'm just a ?precautionist, if that's a word and feel that the information contained in the following threads seems to make sense.
" target="EOF" class="lbg">Site Link
Site Link
http://www.a1.nl/phomepag/markerink/1HD-T_oil-analysis-interpretation.JPG
http://www.a1.nl/phomepag/markerink/1HD-T_pg1-caltex.JPG
http://www.a1.nl/phomepag/markerink/1HD-T_pg2-caltex.JPG
http://www.a1.nl/phomepag/markerink/1HD-T_pg3-caltex.JPG
http://www.a1.nl/phomepag/markerink/1HD-T_pg4-caltex.JPG
http://www.a1.nl/phomepag/markerink/1HD-T_typical-80-series-oil-analysis.JPG
The oil that I use (Caltex CXJ) is, perhaps, slightly dearer than other oils that I may be able to source, but not much, and in the long term it MAY save me money on rebuild, so I'm prepared to shell out that little bit more ( a very small part of the overall runing costs of the car) on the basis of the above. If I'm majorly mistaken or if you can find any technical evidence or quality advice that suggests otherwise, I'm always open to change.
Mark
FollowupID: 513210
Follow Up By: Member No 1- Friday, Jul 13, 2007 at 08:25
I agree with Mark
oils aint neccesarliy OIL
FollowupID: 513229
Follow Up By: Member - Phil G (SA) - Friday, Jul 13, 2007 at 10:24
Hi Mark,
Yep deja-vu.....:-))) But its good fun to bring this up every so often (as long as no one gets serious about it, and I know you don't.
I think the 1990-1994 1HD-T big end issue is a bit old now and irrelevant to subsequent engines. Toyota replaced the big ends with a better bearing and the problem went away. These issues don't occur on any other Toyota motor.
I simply use the engine oils that both Toyota and the oil companies recommend. To do otherwise needs some good evidence, but we know its highly unlikely that you'll do any harm by using other oils of the correct viscosity.
FollowupID: 513253
Follow Up By: Member - Mark E (VIC) - Friday, Jul 13, 2007 at 10:42
Yep, agreed Phil. Certainly not worth getting all ruffled feathers about....I guess it's like many other things associated with cars/trucks/4WD's etc.....we do our own research and come up with what we think is the best compromise for our own circumstances. May not suit everyone.
I don't know whether you read the info on the Castrol jpg's but it certainly had me convinced that for these japanese engines with the lower set piston rings, that a higher sulphated ash content oil will cause less deposits and thus less wear. I tell you what, lets make a pact to discuss this again in about 10-15 years.....I will most likely still have the old 1HZ and by then it will have very high k's...not too sure how long you're keeping yours, but if yours blows up or requires a rebuild and mine doesn't, that'll prove me right..... ;-)
Happy touring....
Mark
Ps Thanks member No 1....at least someone believes me :-)
FollowupID: 513256
Follow Up By: Member - Phil G (SA) - Friday, Jul 13, 2007 at 11:14
Mark,
Yep, keeping mine for a fair while yet. Its got 120k on the clock, and the new V8 won't tempt me.
1Hz vs the 1HD-FTE is probably an unfair contest - we all know the 1Hz goes forever :-)))
phil
FollowupID: 513260
Reply By: Member - Norm C (QLD) - Thursday, Jul 12, 2007 at 19:34
Well I don't know oil from water. I used to use Shell Rimula, until a mechanic I respect told me Rimula is a good oil for older engines, but he suggested that a much better oil for my engine is Penrite HPR 15. And no he was not looking to sell it to me. I buy it where I get the best price.
I've used it since. Can't say that I've noticed a difference (Hilux has done about 50K). I just rely on the advice of those who know more than me. Hope it makes a difference down the track. Worst case, I doubt I am doing any damage. Best case, I might be doing some good.
AnswerID: 252106
Follow Up By: Member - Tour Boy- Friday, Jul 13, 2007 at 08:05
Norm,
Rimula X is for newer motors and Rimula D is for the older ones.
Rimula X is the old Myrena M (spelling) and the D is the old X.
Tour Boy
2015 Fortuner
Had 72 cruisers in my time
FollowupID: 513226
Reply By: madfisher - Thursday, Jul 12, 2007 at 20:02
While I use what my mechanic uses, I know Penrite has always had a very good reputation with engineers and experieced mechanics. I believe they use to source their better base oils from the USA state of Pennsylvania, hence the name. The crude oil from this state was considered the best for making lub oils in the world.
Their cheaper oils are sourced from local supplys.
A friend had a cross axis machine and he use to have a play with diff oils, and penrite always performed well
Cheers Pete
AnswerID: 252110
Reply By: Max - Sydney - Thursday, Jul 12, 2007 at 20:23
I used Penrite Diesel Oil in my 1HZ for years, but when the back of the bottle started to tell me that they were now owned by Shell, and the price started to go rocketing up at the same time I decided that it was time for a change.
The 4WD mechanic that I use now always uses Valvoline, and it seems to maintain pressures, even when a well warmed up engine is on idle, so I have started using that on the minor changes that I still do. Its cheaper too.
As others have said, if it meets the Toyota spec is is doubtless adequate. More important to change the oil and filter every 5000 km than anything else I reckon
Max
AnswerID: 252115
Follow Up By: Member - Norm C (QLD) - Thursday, Jul 12, 2007 at 21:08
Max, this must be a very new development. I understood Penrite to be an independant Family Owned Australian business.
In fact their web site still says as much. Look at any of their overseas websites and they list the Australian office as Head Office.
I just checked the drum I have at the moment and it says 'Penrite is an Australian Company obsessessed with..... etc'.
So unless Shell bought them in the last couple of months and has kept it quiet, I think you might be mistaken.
FollowupID: 513190
Follow Up By: Max - Sydney - Friday, Jul 13, 2007 at 07:37
Norm
Seniors moments are not unfamiliar - I shall go look at a pack in a shop before getting myself in deeper.
It was just a line on the back of their 5 litre packs late last year - I thought.
Red face
Max
FollowupID: 513220
Follow Up By: Member - Raymond S (QLD) - Friday, Jul 13, 2007 at 08:57
Hi Max, I can not fault Valvoline oil as I have been using it since the 70's. We have used it in all types of vehicles from cars, 4x4's, log hallage trucks & tractors in extreme conditions also stationery engines on the land. I believe that its's how you personally service your vehicles & machinery that counts.
I currently run Valvoline in my 2006 Rodeo 3lt T/D.
Regards Ray.
FollowupID: 513236
Follow Up By: Max - Sydney - Friday, Jul 13, 2007 at 18:02
Norm
Definitely a seniors moment - commonly known as a st**f up - I went into Repco today and looked at the back of every Penrite container and none of them said anything about Shell. I checked around the web sites like you had too. So I apologise to Penrite and anyone who took any notice of me.
But its still $1 a litre dearer than it used to and the Valvoline seems fine so I'll stick with it.
Oh well - you win some I guess
Max
FollowupID: 513320
Follow Up By: madfisher - Friday, Jul 13, 2007 at 21:37
Takes a big man to admit he is wrong, good on you max
Cheers pete
FollowupID: 513365
Reply By: brummie pete - Thursday, Jul 12, 2007 at 21:15
Hi howard , I found this of interest as i have had an ongoing problem with my 2h diesel landcruiser in which it kept cutting out in the morning on the first start .
I believe this to be a common problem and can be due to a worn relief valve ,this problem was giving me the screaming abdabs for months so after putting in a new relief valve and a new oil cut off switch plus a decent guage to monitor oil pressure the problem was still there ,so i switched oil from castrol RX super to shell rimula super and the change in how the engine feels and drives and the bonus is the engine doesnt stall on first start because the oil pressure seems to creep up a fraction quicker . I guess oils can be different . pete
AnswerID: 252124
Reply By: Member - Davoe (Nullagine) - Thursday, Jul 12, 2007 at 22:24
I used penrite for the first time last oil change (80 series diesal 230k) andit promptly started piddling oil from the rear seal'
- coincedence???? probably
- would I use Penrite again???
- NO WAY
AnswerID: 252135
Reply By: Steve from Top End Explorer Tours - Thursday, Jul 12, 2007 at 22:39
The first oil change I do on my Toyota's, I change to Penrite without fail I have been using it for 13 years and don't see my self changing soon.
Just my observation when I bought my new car it had just been serviced, they used Castrol the next service was in Mobil Jabiru and of cource they used Mobil the cost of the oil was $85, The next service last night was Penrite, 10lts is $51 Castrol broke down at 4000 km, Mobil broke down at 5000 km, Penrite breaks down at 6500/7000 km, I do mine at 6500/7000 km I also change oil and fuel filters each time.
Cheers Steve.
AnswerID: 252139
Follow Up By: Sacred Cow - Friday, Jul 13, 2007 at 08:37
Steve,
Please advise what are the signs/symptoms that the oil is breaking down so that I can keep an eye open for them in my 4WD?
SC
FollowupID: 513231
Follow Up By: Steve from Top End Explorer Tours - Tuesday, Jul 17, 2007 at 22:47
Sorry for the late reply, I have been extremely busy.
I do 300 km per day, I can tell when the oil is breaking down as the performance of the truck degenerates.
This may seem weird as I can hear the difference, the engine has a what I call a grunge sound, I then check trip B on the speedo and sure enough It is ready for a service.
I put new oil in and the next day it drives and sounds better.
Cheers Steve.
FollowupID: 514146
Reply By: kiwicol - Friday, Jul 13, 2007 at 18:37
If people read their hand book which comes with the vehicle they would find from the manufactors reshearch, the minium blend of oil stating all the ratings needed. Then its up to the individual to pick their own brand of oil up to the stated ratings, then oils become oils. But from my own experience have found changing oils can have an affect on oil consumption and power. I have a 92 GQ diesial 4.2 and have used Valvoline which is Nissans preferred oil and i dont have any oil use between 5000k services and the vehicle has done 340,000ks with a Super Charger sitting on top. Col
AnswerID: 252256
