80 series auto problem
Submitted: Friday, Jul 13, 2007 at 15:25
Member - paul d(WA)
can anyone give some insight into the reason why my auto box is slipping at low revs between 2nd and 3rd even worse in traffic ,any ideas would be great
Reply By: KSV- Friday, Jul 13, 2007 at 17:04
How old ago did you change gearbox oil?
252240
Follow Up By: Member - paul d(WA) - Sunday, Jul 15, 2007 at 10:51
sorry ive taken a couple days to reply,the trans fluid and filter were changed and vit returned within 1000ks
513543
Reply By: oldpop - Friday, Jul 13, 2007 at 21:20
Hi Paul d
Check the kickdown cable adjustment
make sure its not broken if not broken increase line pressure will raise the the shift points of trans
this cable controls line pressure in gear box
regards
oldpop
252275
Follow Up By: Member - paul d(WA) - Sunday, Jul 15, 2007 at 10:56
being a mechanical numpty could u help with the location of said cable and i will give that a go,if that doesn,t fix i guess a rebuild or exchange or s/hand might be the way to go.but thanks again for help and advice cause were stuck in suuny
darwin for a while tough i know!!!!
513545
Follow Up By: oldpop - Tuesday, Jul 17, 2007 at 13:02
Hi paul d
sorry about the delay in getting back to you
the kickdown cable is adjusted at the throttle linkages just adjust about 15mm at a go and check it out you need to pull outer cable back to increase line pressure
hope this helps
regards
oldpop
514018
Reply By: Member - DOZER- Friday, Jul 13, 2007 at 21:58
The slip is called a flare, and it is not good ... usually worn clutches or way overdue oil change or both ....the 1fzfe will kill a auto if it is not maintained every 2 years max...there are a few on sale on www.ebay.com.au they dont usually give bother
252281
