2004 prado turbo diesel sluggish
Submitted: Friday, Jul 13, 2007 at 21:24
jonboy
How can i improve power take off in my 2004 manual turbo diesel Prado ?
Its done 200,000 klm and its a slug on take off
I have only owned the car a few months
If i stop half way up my drive way i have to roll back to the bottom and get a run up
And its not all that steep
Is this normal or is there somthing wrong with it?
Any help on this would be great
Thanks Jon
Reply By: Fazz - Friday, Jul 13, 2007 at 22:04
Jon,
You certainly have a problem there.
Could be valve timming?
Has the cam belt been change recently?
Cheers Fazz.
252284
Reply By: Shaker - Friday, Jul 13, 2007 at 23:12
Clean/replace the air flow meter or get the turbo checked?
252288
Follow Up By: jonboy - Saturday, Jul 14, 2007 at 00:15
How do i clean air flow meter and what with?
thanks
513381
Follow Up By: Shaker - Saturday, Jul 14, 2007 at 14:40
Carby cleaner will do it, but if you aren't confident, get someone to do it for you as they can be quite fragile..
It only takes a few minutes & can make a huge difference.
513412
Follow Up By: Shaker - Saturday, Jul 14, 2007 at 14:43
Sorry, reading down it appears that you don't have one.
Check the turbo.
513413
Reply By: fisho64 - Friday, Jul 13, 2007 at 23:42
umm i hate state the obvious to you but before checking the valve timing etc I would first be changing fuel filters etc. You dont sound like you have much mechanical knowledge so a trip to the dealer you bought it from or a mechanic may be in order if the fuel filter doesnt help.
Would probably be very helpful to give more info too. has it always been this way or was it sudden or gradual? smoke, noise etc?
252290
Reply By: jonboy - Saturday, Jul 14, 2007 at 00:13
It has beenlike this the whole time ive had the car
There is no noises and it drives like a new car
Just has no power at take off
I had the 2000 model diesel prado before this one and it was not under powered like this one and they both have the same motor
The filter is due
How do i check the turbo and what eles could it be?
thanks
252295
Follow Up By: Member - Jason S (SA) - Saturday, Jul 14, 2007 at 07:33
take it in to a serious diesel machanic. Find out what you are up against.
Could be something as simple as incorrect diesel timing. Mad
mine drive like a morris.
Always good to get the injection pump checked anyway on a second hand TD.
513387
Reply By: Member - Phil G (SA) - Saturday, Jul 14, 2007 at 08:16
Jonboy,
Assuming your vehicle is standard (and doesn't have huge tyres etc) Sounds abnormal.
1Kz-te doesn't have an airflow meter, so you can stop looking for that.
If it were me, I'd do everything I could first, and if no better, take it to a diesel injection
shop to get it sorted. So I'd do all items on the major service - oil, air, oil and fuel filters, and check the valve clearances.
Turbo - should hear the whistle when you accelerate; You can check for boost with a boost gauge. You can also take the intercooler off, and check inside the turbo with a small mirror - just check that all the vanes are intact, and that the turbo rolls freely. I had a problem like yours in 2000 with the same motor, and the dealer's mechanic had dropped some stuff into the air intake and chewed out the turbo.
252304
Reply By: Member - 120scruiser (NSW) - Saturday, Jul 14, 2007 at 10:24
I would be interested to know what the economy is with your rig as
I have no dramas with power on take in my 05 TD auto but economy is an issue and has been since new. Do you get good or bad economy on the road. It could be linked.
120scruiser
252316
Reply By: jonboy - Saturday, Jul 14, 2007 at 11:18
I think economy is bad
I get around 400 -450 out of the main
tank
Iam about to change fuel filter now
See if that helps
Will post again later
252321
Reply By: jonboy - Saturday, Jul 14, 2007 at 14:36
Fuel filter did not help
What $$$ will i be up for to get timing belt changed and valve clearance check?anyone no?
And what else could be making it a slug?
252341
Reply By: Heefers - Saturday, Jul 14, 2007 at 16:43
G'day jonboy,
I have a 1kz-te in an '02 Hilux. Had to take the entire intake manifold off and clean out all the crap that had built up, it had nearly half an inch of oily carbon build up on the walls of the intake at around 40,000. This was caused by the crankcase breather (which is fairly low at the back of the rocker cover) seeping oil back into the intake side (via the turbo) which had been mixing with the exhaust gas from the EGR to create this thick oily carbon residue. Could be that your power loss maybe related to the problem I had, a reduced intake manifold volume would certainly do that. Try taking off the charge pipe and having a look down into your intake manifold. If it is chockers with crap take off the intake, clean it out, whack it back together and do what I did, put a catch can in place to arrest the seeping oil from the crankcase breather.
Cheers, Heefers
252358
Follow Up By: Member - Phil G (SA) - Saturday, Jul 14, 2007 at 19:39
Heefers,
The EGR valves appeared on some of the Hiluxes, but AFAIK, none of the 1kz-te Prados. But the Prados did the same thing with the oil - the intercooler gets lined with a film of oil. I wondered what difference this made, so I washed the intercooler out with petrol, dried it out and yep, it seemed to go better. If I still had the vehicle, I might have gone for the catch can like you did.
But the 1HD-FTE on my current vehicle does have an EGR - it must be the most useless piece of gear that ever was put on a motor - I removed the caked up carbon too.
513450
