Mounting Electric Brake Controller
Submitted: Saturday, Jul 14, 2007 at 14:20
Graeme
Have a Hayman Reese "Electronic" Electric Brake Controller.
Question is can these be mounted vertically with the slide control uppermost in the cabin or do they have to be at an incline.
The instructions effectively say that they can be mounted at virtually any angle, but I have been told that a vertical mount is not suitable.
Comments appreciated.
Reply By: Hems - Saturday, Jul 14, 2007 at 15:07
Hi Graeme,
As an accessory fitter, when we fit the units we only look at functionality of the units placement, as in that you can access the slide and the wiring fits etc... there has as far as I am aware through the business that I work for (
well known 4wd franchise) been no known reason that we have come across relating to the unit being vertical or horizontally mounted, only that you can access it easily when needed and its firm mounting. Someone else may have a reason but after fitting a fair few no reason that i can recall.
Hems
252343
Reply By: Andrew from Vivid Adventures - Saturday, Jul 14, 2007 at 17:18
Most controller units gauge braking effect by a combination of brake pedal use and momentum... hence the vertical mounting means that part of the controller won't work that way.
Perhaps the H-R works differently if the instructions aren't explicit about not mounting it vertically.
252366
Reply By: Shaker - Saturday, Jul 14, 2007 at 18:51
As many have said .... "make Google your friend"
You will find all you need here Site Link
& took all of 1 minute.
252388
Reply By: Graeme - Saturday, Jul 14, 2007 at 22:11
Thanks for the feedback. The instruction sheet that I have [came with the unit] is different to the page now available on the internet, so I will copy that and show it to the auto electrician who told me the unit will not work if mounted vertically.
Will soon find out when I hook up the van on Tuesday
252422
Follow Up By: John R (NSW) - Sunday, Jul 15, 2007 at 06:30
Graeme, the Hayman Reese is a very rudimentary controller which does not use the pendulum principle to regulate the voltage to your brakes. You can mount it any way you like, provided you can reach and operate the slide controls.
I had one for a previous camper trailer, and replaced it with a more useful model because I had to continually adjust it to the conditions.
513501
Reply By: Member - Wayne B (QLD) - Sunday, Jul 15, 2007 at 11:24
I would place it where i can get to it and use the slide. I came down an incline once offroad and had to make adjustments on the way down as the trailer was locking up and sliding due to the track surface. Of course if you are sticking to only the road then it probably does not matter
252504
