hj47 glow plugs
Submitted: Sunday, Jul 15, 2007 at 15:03
antmisk
Hi I have just purchased an 81 hj47 which is great. The problem I have is what glow plugs to use. the engine is a 2h 10/83 the glow plugs in it were a mix of 8.5v & 6v has anyone got any sugestions on which plugs to use.
Thanks Anthony
Reply By: peterjs - Sunday, Jul 15, 2007 at 16:58
Hi Anthony, I have the Toyota Land cruiser repair manual and 2H engine repair manual, just checked in the preheating section and this is what it says, hope it helps,
Load current, remove the glow plug connector,
connect ammeter between glow plug lead wire and one glow plug,
turn the starter to glow position and measure the load current after about 40 seconds,
load current per one glow plug 12V type 7.2 - 9.8A
Pete
252549
Reply By: luch - Sunday, Jul 15, 2007 at 21:14
Anthony
The 8.5v is the standard glow plug, the 6v is a fast heating glow plug (they warm up fast but dont last as long)
i would use the 8.5
252620
Reply By: antmisk - Sunday, Jul 15, 2007 at 21:25
thanks for the info I will go with the 8.5v
Thanks again
Anthony
252624
Reply By: Member - Phil G (SA) - Sunday, Jul 15, 2007 at 23:56
Can't tell you what to use.
But the "superglow" system came out in about 1982. Given that your vehicle is 1981, and the engine is 1983, then it could have either system. The superglow has the lower voltage glow plugs because all the power goes through a preheat element first, so there's a substantial voltage drop before the current hits the plugs.
252655
Reply By: Member - Scott M (NSW) - Monday, Jul 16, 2007 at 00:17
Anthony - good to see another HJ47 owner around here - great old beasts - can't kill them :-)
252657
