water supply
Submitted: Sunday, Jul 15, 2007 at 16:03
pauls
I want to store my
water containers in the back of the ute but when fully loaded they are difficult to access without unloading a heap of stuff.
Has anyone got a set up using a 12v pump and tap.
Just looking for some cheap simple ideas.
Paul S
Reply By: Member - andrew B (Kununurra) - Sunday, Jul 15, 2007 at 16:28
Gday Paul
With jerry can type (rigid) containers, I think you may have some problems snapping taps and hoses off etc, depending on the way they are restrained on the ute...I ended up going for a flexible bladder, which holds (supposidly) about 120 litres. It fits perfectly across the back
seat floor, which is great for me with small kids and a wagon, low and central with the weight. You could look at something similar in the back of the ute in a plastic toolbox or even a plywood box. gravity feed via a hose out the door works good for me, with a tap and push on hose fitting for ease of filling and draining.....I have thought about a 12 v pump as
well, an inline type hat is portable and can be used for filling as
well as draining, but haven't needed it yet.
Not really what you asked, but may be a good option for you, may even be scope for fitting it under the tray somewhere, and much cheaper than a permanent
water tank
Cheers Andrew
252544
Reply By: Peter L - Sunday, Jul 15, 2007 at 17:10
Paul...I went to a caravan
shop and got an in-line 12 volt pump and hooked this up from the
water supply to a tap on the rear wheel carrier. I then wired a on/off switch in the back of the truck...all up cost under $100.00....Cheers
252553
Reply By: Member - Drew T (Melbourne) - Sunday, Jul 15, 2007 at 20:30
I've used a jiggler siphon before so I didn't have to unload the
water containers to use them. they are very easy to use. (buy them in hardware &
camping stores)
252595
Reply By: Crackles - Sunday, Jul 15, 2007 at 20:55
Paul we use a 12Volt shureflow pressure pump. Just cut a hole in the lid of one jerrys using food grade
water hose (to minimise bad taste) with a trigger tap on the end & a toggle switch to turn off avoiding accidental loss of
water. Town pressure out of the back of the car & handy for putting out a spinifex fire.
Cheers Craig...........
252611
Reply By: Member - Phil G (SA) - Sunday, Jul 15, 2007 at 23:50
Paul,
Best cheap simple idea is to have a syphon hose permanently mounted thru a hole in the cap. Put an irrigation on/off tap on the end, and a small breather hole in the cap. You'll be surprised how
well it flows, and nothing electrical to complicate things. Naturally you'll need enough length on the hose to get it lower than the jerry.
252653
Reply By: draff - Monday, Jul 16, 2007 at 08:31
We used to have the large
water containers but had the same problem as you regarding access. We bought a plastic caravan
water tank which we mount in the back
seat area and run a hose down that goes into a clip on the side step - a simple tap turns it on and off and gravity does the work for us! we have a breather hose that is attached up the cargo barrier. I am sure you could adapt this to suit the back of the ute.
252671
