INVERTERS
Submitted: Sunday, Jul 15, 2007 at 21:23
Member - Matt & Julie (VIC)
Hi all have just given myself a present, A Toshiba laptop satellite A200. what I need is an inverter to charge it while away. where do I start looking? I am on the Mornington Peninsula and travel to Melb daily. OH and what size ?
Thanks in advance
Reply By: Member - craig W (VIC) - Sunday, Jul 15, 2007 at 21:28
Try aldi mate $60 for 300 watt had
mine for 2yrs its never let me down
252627
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Jul 15, 2007 at 21:32
Hi Matt
A 350 to 500 watt unit will be fine.
Try make sure it has a good modified wave.
Here is my indication chart of what can be run off our 500W marine inverter.
252628
Follow Up By: Big Mike - Sunday, Jul 15, 2007 at 21:38
Does it have to be a "sine" wave thingo or will the standard one do, pardon my electronic ignorance.
513681
Follow Up By: F4Phantom - Sunday, Jul 15, 2007 at 21:46
no it does not have to be pure sine wave, and if its only a laptop 150w is ok, but if your like most people you will want to start using other stuff too in my case cordless drill chargers and other power tools.
513687
Reply By: fisho64 - Sunday, Jul 15, 2007 at 21:44
If your on the Mornington peninsula and travel daily to
Melbourne, do you actually need an inverter? Perhaps the battery is knackered in it?
252634
Reply By: Member - Hunz (NSW) - Sunday, Jul 15, 2007 at 21:50
I got myself a Dell Laptop and it came with a charger kit, that has a 12v Cig Lighter adapter. So the power supply can also take a 12v input. Don't need an inverter then.
252637
Reply By: Member - City_Wombat - Sunday, Jul 15, 2007 at 22:03
Matt & Julie,
I have a Toshiba TE2000 laptop. My 150w inverter will not run it. The inverter cuts out. It runs perfectly OK on a 300w one. As other have mentioned you will probably run other things on the inverter as
well, so get a bigger one and save youself money in the long run..
Allen
252640
Reply By: Member - Phil G (SA) - Sunday, Jul 15, 2007 at 23:32
You may not need an inverter if your Tosh runs off 15 volts. I run an older Tosh directly off the 12 volts in the car, (14.2 volts when driving), and the computer runs fine, even though it has a dead battery. I think the newer Tosh are still 15v.
252649
Follow Up By: Robin Miller - Monday, Jul 16, 2007 at 07:58
Hi Phil
Yes the Toshiba satellite still use 15v don't really need an inverter , just a good lead made from parts from Jaycar etc.
Interestingly we had visitor the other day who had a quite small laptop and it ran off 12v as opposed to 15v , was a Samsung - must check out further as my Toshiba Satellite is a few years old and has almost forzen up.
Robin Miller
513712
Follow Up By: Mike Harding - Monday, Jul 16, 2007 at 08:05
I would not advise this - especially with a new laptop.
I'm guessing that the amount of filtering of the power supply inside the notebook is minimal as the notebooks _expects_ to be fed from it's OEM supply and that supply will ensure its output power is clean.
The raw 12V system on a car is _terrible_ with all sorts of noise and voltage spikes (tens, maybe hundreds of volts) and there is no way of knowing how
well, or badly, the notebook may cope with these.
Proceed at your own risk - but, no way, would I do it.
Mike Harding
513713
Follow Up By: Robin Miller - Monday, Jul 16, 2007 at 08:24
Hi Mike
There is no risk at all with that particular PC range, and voltage is actually further processed and cleaned up to charge the Li batteries.
Works
well and is makes more sense than to upconvert 12 to 240 just so that it can be downconverted in another device back to 14v with poor overall efficentcy, dangerous volts and unecessary leads and equipment.
The downside though is that charging really only occurs when engine is running and you need good lead (> 1mm2 ) so that you do not get any further volts drop.
Robin Miller
513717
Follow Up By: Mike Harding - Monday, Jul 16, 2007 at 08:41
Hi Robin
As I'm sure you know; in order to decide if this was a safe practice a detailed engineering examination by a competent person of the internal circuitry of each model of notebook computer one intended to do this with would need to be undertaken and an assessment made of the capability of the device to survive in an automotive environment. It makes no sense for notebook manufacturers to go to the considerable extra expense of protecting their products against automotive supplies when they never expect them to be connected to one.
Frankly I'm surprised you're recommending it to people.
Mike Harding
513718
Follow Up By: Robin Miller - Monday, Jul 16, 2007 at 09:30
No need to be suprized Mike, I'm qualified as per your specs, but on same basis I cannot at this stage reccomend the Samsung , but I expect it to be ok.
Its reasonable to be concerned as they are an expensive purchase and its good to know that several of that model have been run on multiple cars over approx 5 years now under my direction, but its comforting to have the practise back up the theory.
Robin Miller
513723
Follow Up By: Member - Phil G (SA) - Monday, Jul 16, 2007 at 09:40
Robin,
That Samsung is the Q1. Came out earlier this year - looks like the perfect computer to mount to the dash for mapping. Runs on XPtablet edition. Has a CF card reader too.
I was pretty keen to get one after breaking the screen on my old tablet, but I've since resurrected an old Tosh running 98SE with 64Mb ram, 6gig HDD, and a video output that goes straight to my 7inch dash screen. We work it on the move with a cordless mouse. So I'll stick with that for a while.
513725
Follow Up By: Robin Miller - Monday, Jul 16, 2007 at 10:11
Sounds good Phil , if its like the old Satellite 4030ct I have gathering
dust somewhere here then the external screen would be a desirable option.
Personally I have gained the impression that Samsung products need to be treated warily.
In this case it belonged to a senior executive of a Korean LED manufacturer, he sat down to give us a demo of some new super LEDs and his PC failed to work - determined that it was bad plug on power supply, and I gleefully cut the end off the lead and soldered a new connector on, and stuck some shoe-goo over the exposed 12v plug ends .
After the demo I asked for more than the usual amount of free samples which duly arrived and everybody lived happily ever after.
Robin Miller
(P.S. - When arrived back from Warraweena - my new Garmin 276c had just landed - and it certainly has the screen performance I was expecting)
513730
Reply By: Member - Doug T (W.A) - Monday, Jul 16, 2007 at 01:32
Matt & Julie
I seen a very good page on
Inverters right here in EO a few weeks back ...now I can't find it
Try this one then www.latronics.com.au/index.html
Doug
252659
Reply By: Member - Doug T (W.A) - Monday, Jul 16, 2007 at 01:44
Reply By: MEMBER - Darian (SA) - Monday, Jul 16, 2007 at 09:09
I bought a multi - output DC to DC transformer at Dick Smiths - 12V in and a choice of a outut voltages - mix of plugs too for popular computers - seemed the ideal setup, seeing putas run on DC-
mine is 17V.
252674
Reply By: Mainey (WA) - Monday, Jul 16, 2007 at 13:37
Look at the various brands available and select one that fits your requirements including:
mounting position, fan cooled not just cheap heat sink, concider going up to 300 Watts because you can use it to make the tea/coffee, charge all the spare batteries etc.
Make sure it is PURE sinewave !!
Check the EFFICIENCY % number, don't settle for anything less than ~90%
252697
Reply By: Member - Mick O (VIC) - Monday, Jul 16, 2007 at 18:54
Bugger the inverter. Very cumbersome fror what you want. Go into Dick Smith and check out the Kerio Adapters (they're on the DS website to). Purpose built to do the job, plug into the cigarette lighter and no messing around with an inverter. Two sizes. One is about $80 and the other (for larger computers) is $120. On the backs of the packets it lists the computers that each unit will power. The much simpler and safer option.
Cheers. Mick
252746
Reply By: Members - Bow - Wednesday, Jul 18, 2007 at 08:23
Jarcar Power Teck Plus for $49. It has adjustable voltage and will drive most laptops from a 12v source.
Be careful with voltage my Toshiba uses 19v.
253103
