What GPS to buy?
Submitted: Sunday, Jul 15, 2007 at 21:50
babs
Ok so I have palmed off the Tom Tom to the misses.
So what do I get? I like the Magellan XL because of its 4wd tracks and fire
trails but don't like the fact that it does not speak to you or does not have a touch screen.
Is there another brand that is compatible with the Auss Topo (I think this is what it is called covers 4wd track?) that comes with the Magellan XL.
Does the Garmin work with this or does it have its own 4wd track maps?
If I assume right, there is an available 4wd map I can buy off this site, what GPS is compatible?
Regards,
Babs.
Reply By: Member - Doug T (W.A) - Sunday, Jul 15, 2007 at 21:57
www.doug-and-dusty.id.au/maps.htm
252638
Follow Up By: Member - Mike DID - Monday, Jul 16, 2007 at 19:02
Thanks Doug - that's a wealth of handy info you've collected there.
513827
Reply By: Member - Oldplodder (QLD) - Monday, Jul 16, 2007 at 07:59
Few choices.
Decisions I went through.
Decides size reqd.
1. Used mainly in the car?
2. Or also some use while walking?
Decides map functions.
What detail do you require on maps?
Want to go proprietry maps like Auss topo, or use oziexplorer and buy more maps?
How much time do you have, or are you willing to fiddle with setup?
(these decide GPS or PDA, oziexplorer runs only on PDAs, and out of box solution points to GPS)
Do you want voice directions?
Oziexplorer (with some setup of
routes) and software like co-pilot give voice directions. If yes, it will need to be PDA.
How much do you have to spend?
PDA, software and maps is going to be at least or about $1,000.00.
252664
Follow Up By: Member - Doug T (W.A) - Monday, Jul 16, 2007 at 12:21
Only problem I have with PDA's is that they are not waterproof/Dustproof so in the Outback they will get ingressed with bulldust in the keys and buttons and slots etc.
Actually just as I was about to hit the Submit button I thought ....hey Len Beadell didn't have all this Laptop big screen GPS stuff.
Doug
513750
Follow Up By: Garbutt - Monday, Jul 16, 2007 at 14:08
If Beadell did have puters he might have spent all his time on the
Forum answering questions instead of being out there. LOL
GB
513772
Follow Up By: Member - Oldplodder (QLD) - Monday, Jul 16, 2007 at 15:35
Good point about dust and weather Doug, if at all for outside use, or very dusty, go GPS.
Garbutt, yep, and most of the
explorers didn't have them either.
But then I don't think I could do the maths they used to do either. :o)
Or have the patience to sit down for a day or two to back check sightings like Len use to do.
I still work for an old fashioned surveyor sometimes, and have to manually lay out all of his sightings, and check for closure.
513783
Reply By: Robin Miller - Monday, Jul 16, 2007 at 13:28
Hi Babs
I agree with others that you certainly need to think it thru and decide
on some key issues, as apart from maybe the Garmin 276c there is perhaps no blanket reccomendation that can be made.
Touch screens etc tend to imply more of a navigator than an all round GPS
but some of these like Nuvi/Quest are doing a better job of both with a lot of crossover features. I have recently organized several Nuvi 660 and the people have been very happy.
The Xl has some good points , but while they have come a lot way they do
not yet have the screen resolution or brightness to match the sunlight
readable capability that I required.
I play with mapping and drive a lot on tracks I preload , this is time consuming
and the range of features and definability in 276c made it a unit you can grow
and have a long term relationship with wether its 4wding or boating
If you go down the path of these type of units they are expensive , but can be brought overseas. This involves some issues and is not for all and is better subject of another post.
Robin Miller
252694
Reply By: swampy66 - Monday, Jul 16, 2007 at 14:04
babs
choice magazine have just done a review GPS's
i think you can buy a single review - as opposed to subscribing to the site.
Site Link
good luck
252706
Follow Up By: Member - Oldplodder (QLD) - Monday, Jul 16, 2007 at 15:38
I think they may be more in car navigation systems rather than what I would call a GPS unit. But the difference is becoming blurred these days as more options are added to GPS units.
513784
Follow Up By: Member - Doug T (W.A) - Monday, Jul 16, 2007 at 16:22
Oldplodder
Maybe you would be happier being like Dick Tracy...cough....cough
www.ja-gps.com.au/garmin_foretrex201.html
Doug
513790
Follow Up By: Member - Oldplodder (QLD) - Monday, Jul 16, 2007 at 20:45
Good one Doug, and some one invented a wrist size mobile phone a while ago.
Put the two together and it would be DT.
And we used to laugh at DT talking into his wrist watch.
513863
