Noisy Water Pump
Submitted: Monday, Jul 16, 2007 at 19:38
Member - Peter B (VIC)
We have a Windsor Rapid which has a SHURflo
water pump located under the
seat and screwed to the floor. Pump has rubber feet. Trouble is the B thing is very noisy and we are reluctant to use it, at night, if someone is beside us. I have made a wooden box which I stuffed with foam to try and quieten it down but it made little difference. Any
bright minds out there with any suggestions. We checked with dealer about the noise level and were told it was normal, and have asked one other van owner about his pump and he said his was the same . HELP PLEASE. We use the van
water for drinking, no fluoride.
Reply By: Member - Mick M (QLD) - Monday, Jul 16, 2007 at 19:41
remove it and relocate under the floor close to
tank.my mate has same prod on his new van regards mick
252767
Follow Up By: Member - shane (SA) - Monday, Jul 16, 2007 at 20:52
had the same problem with
mine, replaced it with the flojet 35psi /12ltsmin. quiet as. if you have a look at the pump it only has about a 6 or 8 mm hole in fittings for hoses. there to small. the other pump has about 13mm outlets.
513867
Reply By: MEMBER - Darian (SA) - Monday, Jul 16, 2007 at 20:51
We have one on our camper trailer - as you say noisy as hell - the "lady of the expedition" hates it (so I use it all the time)...... but as you say, when parked 'cheek by jowl' with other campers its hardly fair - we use the
hand pump then. Was going to try and quieten ours but its in an incredibly awkward place - if it fails, it'll be a bugger of a job to get to it. Too hard basket here........
252795
