Timing belt, chain, or gears?.
Submitted: Monday, Jul 16, 2007 at 19:40
Member - Axle
I'm back to that stage where the timing belt needs changing, (more Money), Just keep wondering which is best?, chain , belt, or gears. Belts are vulnerable if alignment is not correct, and tensioner bearings can be a worry, chains running in oil seem to be reliable, and when worn you get that warning rattle. Gears to me are the best, but no manufacturer seems to interested in developing a strong lightweight gear that's not noisy and can cope with the modern diesel design. in the timing area that is. Any Thoughts?.
Cheers Axle.
Reply By: Eric Experience - Monday, Jul 16, 2007 at 20:47
Axle.
Mercedes use a chain and have for almost 100 years, they have never used a belt, as they are the world leaders of design in small diesels that says it all. Eric.
252793
Reply By: Exploder - Monday, Jul 16, 2007 at 20:51
The general Consensus is a good double row chain is the best and will generally outlast the engine, gears can be a PITA, can be hard to set up right and make a bit of noise, thou they are quite durable too, allot of Diesels run gears just not Jap diesels or small diesel engines.
Personally I don’t like the idea of my engine’s life being in the hands of a rubber belt .
that's my view anyway.
252794
Follow Up By: Member - Axle - Monday, Jul 16, 2007 at 21:19
And really, its my view to exploder!. Hate Belts!!.
513882
Reply By: Member - Doug T (W.A) - Monday, Jul 16, 2007 at 21:04
Axle
Was something one never give a second thought about when we moved about in 50s and 60s Holdens etc
252806
Follow Up By: Member - Axle - Monday, Jul 16, 2007 at 21:16
Hi Doug.
And 50s and 60s trucks, tractors, motorbikes, etc. Have just wittnessed a belt failure in a late model astra. Yuck, what a mess!!!.
513879
Follow Up By: madfisher - Monday, Jul 16, 2007 at 21:35
Hi Doug,
I actually had the fibre timing gear break a tooth off on a 179 motor in a hd about 1971. When we use to warm these motors up a bit we use to use a alloy timing gear which was a bit noisey but reliable. I am not looking forward to repacing the belts on the Jack and Paj.
Cheers Pete
513897
Follow Up By: Member - Doug T (W.A) - Monday, Jul 16, 2007 at 21:59
Axle
Like everything these days, ....Disposable , take ..um err Nappies , use them once and throw them on the ground in a
parking bay, My Mum used to wash them and use them wash them and use them probably same ones over a 14 year span , I probably had my older sisters lot and my younger sister used them too
513908
Reply By: Robin Miller - Monday, Jul 16, 2007 at 21:08
Interesting new layout - had a little trouble sorting out the posts - but back to the subject ,
well I'm biased as the bolts in my timing gear fell off and gears jammed and Nissan brought me a new engine as a result.
Robin Miller
252810
Follow Up By: Member - Axle - Monday, Jul 16, 2007 at 21:26
Yeah, But thats nissan engineering for you!!!......:)))))))).
Bit like the new mazda ford diesel problem??
MMMMM.! looks like gears are out......lol.
Axle.
513888
Reply By: Flash - Monday, Jul 16, 2007 at 21:33
Timing belts are a disaster!
They have cost me one engine in the past.
On almost any modern engine a broken belt means a broken, as in, destroyed engine.
Give me a chain any day- it's something I look for in a new car!
Gears work with a side cam, but not overhead cam.
Hooroo
252821
Follow Up By: Member - Axle - Monday, Jul 16, 2007 at 21:41
Bring back the old donks!!, cast heads , side cams, bugger the alloys , and rubber crap.
Cheers Axle.
513902
Follow Up By: madfisher - Monday, Jul 16, 2007 at 22:18
yes Axle I remember geting 11mpg arround town from my fj40, lots low down torque but no road speed. Thank you but no thank you
Cheers Pete
513916
Follow Up By: Exploder - Tuesday, Jul 17, 2007 at 18:59
And
well we are at it we may as
well bring back the Flat head V8 LOL
514090
Reply By: tempestv8 - Tuesday, Jul 17, 2007 at 12:10
If I had to choose, it would be chains first choice, followed by timing belt and last by a country mile would be gears.
Do a search on Zeus timing gears and you'll soon find that these things break on Land Rover diesel motors. Not sure if timing gears in other vehicles are reliable or not.
252928
