Dual Axle Wheel Alignment
Submitted: Monday, Jul 16, 2007 at 20:50
ThreadID: 47780 Views:3840 Replies:3 FollowUps:1
I have a dual axel caravan which is wearing the tyres on one side unevenly.
Presumably i need a wheel alignment. Is it just a matter of making sure the axels are parallel and at right angles to the chasis? Can I do this with a tape measure?
Is there a machine that is needed. Advice please.
Reply By: Richard Kovac - Monday, Jul 16, 2007 at 21:02
Hi Andrew, nice rig
Try these sites, Hope it works.
Cheers Richard
dexteraxle.com/i/u/1080235/f/6_8k_service_manual_4_06/Wheels___Tires_2-07_72_res.pdf
http://dexteraxle.com/i/u/1080235/f/6_8k_service_manual_4_06/Suspension_Systems_2-07_72_res.pdf
AnswerID: 252803
Reply By: Richard Kovac - Monday, Jul 16, 2007 at 21:06
Dam it try this
www.exploroz.com/Members/FileSwapDownload.asp?File=20070716_Suspension_Systems_2-07_72_res.pdf&Docs=Vehicle Info
AnswerID: 252809
Follow Up By: Richard Kovac - Monday, Jul 16, 2007 at 21:09
Maybe???
Site Link
Suspension Systems Tandam axle
FollowupID: 513873
Reply By: Gjenko - Tuesday, Jul 17, 2007 at 17:38
Hi Andrew
I had the same problem with the left rear tyre on the van wearing on the inside. Turned out to be wear from the pin on the hanger. The little weld had let go and allowed the pin to swivel and wear an elongated hole in the hanger which in turn allowed the spring to go out of true.
The fix was is to check the pins in the centre of the Hanger which is in the middle of the wheels and it should be welded to the hanger. If not, that could be the problem. Replace the hanger and pin and that was my fix.
Hope you find the problem
regards
Jenko
AnswerID: 252986
