Navman N40i loading maps
Submitted: Tuesday, Jul 17, 2007 at 00:08
imjames
Is it possible to load detailed outback maps similar to Hema maps onto the Navman N40i? What outback software / Program can I load onto it? Im traveling to
birdsville and
corner country and keen to get some maps loaded. Not sure how to do this. There is pre loaded "whereis.com" maps on it. I also am aware that with GPS units there are city based ie TOM TOM and my unit , and those for outback ie Magellan, Garmin, anyway any thoughts or advise would be welcome. thanks guys
Reply By: Kiwi Ray - Tuesday, Jul 17, 2007 at 07:28
Hi.
My advise is leave your N40 as it is, and use a standard GPS unit with good detailed maps of the regions you are traveling in.
Make sure that GPS and maps are using the same formatand datem.
Adjust lat and long to To ddd,mmmmm as this is quite easy to relate to metres on the ground. If Your maps have a
grid system on your maps this is even better.
Set up your GPS with track up and reading true north, this now looks the same as you map as you look at it.
Set up gps with snail trail and auto wrap.
With this set up the gps will follow you and if you make a mistake you turn around and follow your trail back to a known point.
You do need to mark your position regularly.
Now all you need to do is learn to transfer the gps's position info to your map
Also learn what the figures mean in relation to distance on the ground
Hope this is of use
Ray
252878
Reply By: Member - Andrew (QLD) - Tuesday, Jul 17, 2007 at 07:40
These type of devices use vector data (line/point/area data) instead of map images. As such i would be surprised if there is any software that is available to upgrade the Navman N series.....i have a N60i and haven't seen anything yet.
Remember that these devices are mainly designed for route guidance, usually via voice, and as such they need certain data in order to function correctly.
The better options include a seperate laptop/pda etc running specialised software eg OziExplorer, with a GPS interfaced, to navigate these areas.
252881
Reply By: Member - Toolman (VIC) - Tuesday, Jul 17, 2007 at 08:40
imjames
Regrettably the answer is no. To my knowledge you cannot load any type of map onto this type of device unless it is an update of the proprietary data already loaded or another proprietary product issued by the maker, which at this time doesn't exist .
To do what you intended , you need a PDA type GPS system such as the ASUS MYPAL 636, or similar device together with a program like OziExplorer or a laptop setup running OziExplorer.
Toolman
252894
Reply By: Member - Doug T (W.A) - Tuesday, Jul 17, 2007 at 11:12
imjames
I think all the others have given you the answers you need , I just thought you might like to see what Garmin City Nav' 7 matched with T4A can do , just under the 4 gps units are 2 little maps, click on them . left 1st then the right 2nd
www.doug-and-dusty.id.au/maps.htm
Doug
252917
