fuchs oil
Submitted: Wednesday, Jul 18, 2007 at 12:02
ThreadID: 47835 Views:8281 Replies:11 FollowUps:13
gday all,
just bought a 100series td off a bloke who only ever used fuchs oils. he highly recommends this product. the car is now due for service and fuchs oils are, i found out, dearer than most. i know ythis is a petty question but not being a mechanical know all, do i continue with the fuchs oil or use the mobil oil my mechanic recommends?
cheers dave
Reply By: fisho64 - Wednesday, Jul 18, 2007 at 12:08
FUCHS oil is good but when we were buying by the 44 a couple of years back it was cheaper than the other name brands?? and we used in everything on the boat-engine, generator, gearbox, hydraulics, steering etc etc.
If the MOBIL is the correct grade and type for your TD there is NO REASON WHATSOEVER not to use it.
AnswerID: 253137
Reply By: fisho64 - Wednesday, Jul 18, 2007 at 12:11
FUCHS is good oil but when we bought it by the 44 a few years back it was cheaper than the other name brands. And we used it in everything-main engine generators gearbox steering hydraulics etc.
If the MOBIL is the correct grade and type there is no reason whatsoever not to use it though.
just tryed to post this a second ago and all text etc disappeared upon "submit reply"
AnswerID: 253139
Follow Up By: Member - Doug T (W.A) - Wednesday, Jul 18, 2007 at 22:17
Don't worry about it, just an ECHO
FollowupID: 514358
AnswerID: 253141
Follow Up By: fisho64 - Wednesday, Jul 18, 2007 at 12:12
after 3 attempts all appeared at once??
FollowupID: 514216
Follow Up By: dave_c - Wednesday, Jul 18, 2007 at 12:19
gday fisho64,
thanks, if the same grade and cheaper, i will trust my mechanics better judgement and save a buck or two
FollowupID: 514220
Reply By: Ingtar - Wednesday, Jul 18, 2007 at 13:11
I have been using fuchs in my 1100cc motorbike for around 50,000kms now. I can't remember why I first started, but after changes it seemed to stay cleaner and 'more oily' (ie hadn't lost lubrication properties) than previous oils I had used (including mobil).
Note this is not scientific, just what I observed when doing regular changes. It is also a different application, motorbike oils have different properties to other oils due to wet clutches etc.
I tend not to use it in my N/A 1HZ. I buy drums of whatever oil is available that meets specs. But I will go out of my way to buy it for the bike, as I know it is good.
AnswerID: 253152
Follow Up By: fisho64 - Wednesday, Jul 18, 2007 at 13:45
"whatever oil is available that meets specs"
you hit the nail on the head there, with the proviso that the company whose name on the label is reliable with their labelling of course.
People sometimes waffle on that you shouldnt change brands as the engine gets "used" to it, and will sh*t itself if you change. Piffle. But you certainly are correct that a MC engine has different requirements and are restricted in what can be used.
Id probably use FUCH's in my 100TD but I dont often see it in smaller quantities. We only bought it in 44's at $698.
FollowupID: 514238
Follow Up By: dave_c - Wednesday, Jul 18, 2007 at 14:02
fisho64,
you say probably use fuchs. do you believe it to be better than mobil and the like.
FollowupID: 514241
Follow Up By: fisho64 - Wednesday, Jul 18, 2007 at 14:06
not necessarily better. But it did work well in all our machinary and was cost effective (at least it was???) What I do believe is that the quality difference between equivalent reputable oils is much less than the price difference which can be 100%. Quality definitely isnt 100% better and you wouldnt know if it was anyway!
FollowupID: 514243
Reply By: Member - Phil G (SA) - Wednesday, Jul 18, 2007 at 14:08
I have the same motor - used the 15W40 Fuchs for a few years and now use the 15W40 Gulf Western stuff that is CI-4 and in 20litre drums. Don't worry about the brand, look at the specs and viscosity, which should all be above that specified by Toyota.
"Oils is oils, Sol" ...........:-)))
AnswerID: 253160
Follow Up By: dave_c - Wednesday, Jul 18, 2007 at 14:29
phil,
thanks, only thing i have ever been good at is bricklaying. understanding engines and their requirements is something i cant even pretend to know. just wanting to know that im doing the right thing. cheers
FollowupID: 514249
Follow Up By: Member - Phil G (SA) - Wednesday, Jul 18, 2007 at 19:01
Dave, I'm no mechanic either, but I really admire a good bricklayer! Fantastic skill.
Your Toyota manual will tell you to use different oils for different temperatures. Translated, that means you need a 15W40 or 10W40 for the conditions we get over most of Australia. Secondly, the specs of that oil need to be CF grade or higher.
So any diesel engine oil that is CF, CF-4, CG-4, CH-4, or CI-4 is fine. Most Toyota dealers and workshops use a mixed fleet CF grade oil.
FollowupID: 514317
Follow Up By: fisho64 - Wednesday, Jul 18, 2007 at 22:48
you can come and do some bricklaying on my shed and I'll change your oil! Sh+t I'll even supply it!
FollowupID: 514368
Follow Up By: dave_c - Thursday, Jul 19, 2007 at 13:17
hey fisho64,
where are you. im temporarily out of work cos of the big wet here in the west of melbourne. may be able to help you. lol.
cheers dave
FollowupID: 514426
Follow Up By: fisho64 - Thursday, Jul 19, 2007 at 22:33
Midwest WA
If your a brickie, plaster, tiler, grano worker, sparkie, plumber, chippie, boily, fitter, mechanic, plant operator or anyone else with two arms and a heartbeat etc etc etc what are doing over there anyway???!!!
FollowupID: 514528
Reply By: Exploder - Wednesday, Jul 18, 2007 at 21:19
We use Mobil Delvac 15W40 in the Big Diesel MTU's at work, that's probably just cause that's what MTUDDC tell us to stick in LOL
It was Shell at one stage too, but Mobil Looks to be the new oil now.
Mobil is a Good oil same a Fuchs, Go with what ever, If you can get it easily stick with the Fuchs, otherwise just go with the Mobil, A mechanic is going to tell you to use what ever oil he uses in his workshop.
cheers.
AnswerID: 253246
Reply By: Member - Michael J (SA) - Wednesday, Jul 18, 2007 at 21:29
G'day Dave,
I have never used fuchs oils.........never been able to pronounce it correctly...lol
Not much help I guess;))
BTW if you use the spell check you get an interesting alternative!!!!!!!
Michael
AnswerID: 253251
Follow Up By: Nick R (VIC) - Thursday, Jul 19, 2007 at 17:17
Hey Michael,
My mechanic pronounces it fooks (rhymes with books).
Got home today, my port and red wine is right where I left it!!!
NickR
Carpe Cerevisi
FollowupID: 514458
Follow Up By: Member - Michael J (SA) - Friday, Jul 20, 2007 at 10:21
Morning Nick,
I believe you had to head north for a while to thaw out :))
-and why would your port and wine not be there, not hot enough to evaporate..lol
It has been port weather here for the past week or so, scape the ice off each
morning, the car that is.......no wonder Willie headed to Darwin with George.....lol
Take care
Michael
FollowupID: 514568
Reply By: Member - Pesty (SA) - Wednesday, Jul 18, 2007 at 23:22
I have been using Fuchs oil for a while now, as I have started buying it in 200l drum.
I use it in every vehicle on the place, Diesels, petrols and gas, small motors and large, and having no problems with it.
Use there gear oil's too.
As above, just make sure the rating is correct and I dont think it matters which brand.
Cheers Pesty
AnswerID: 253275
Reply By: Member - Doug T (W.A) - Wednesday, Jul 18, 2007 at 23:25
dave
First time I used that name on here it got bleeped out , had to get David to sort it out ...lol damn computer thought i was swearing. Yes good oil that , I use it when I can get it .
Doug
AnswerID: 253277
Reply By: k9 - Thursday, Jul 19, 2007 at 04:56
I love Fuchs ....... they send my cheques back each time. For some raison, someone else is paying my bill via EFT.
Thanks to the unknown person/business
AnswerID: 253290
Reply By: dave_c - Thursday, Jul 19, 2007 at 13:22
gday all,
good work you all, i have opted to continue with the fuchs. i will see what progresses over next few years.
cheers dave
AnswerID: 253334
