OZi Explorer
Submitted: Wednesday, Jul 18, 2007 at 18:44
ThreadID: 47850 Views:2124 Replies:4 FollowUps:2
I am trying to set up Windows 95 OZI & a Garmin 76 via a serial port.
OZI is working fine I am just trying to get the right Com or serial port drivers, also on the GPS menu I can only get the baud rate to 4800.
This is a TAFE computer.
Can anyone with with these settings.
I have all working on Mine XP, Magellan & USB cable. Magellan I can get to 9600 Baud rate. But the Garmin on another Computer I can only get to 4800.
Thanks in advance, Kevin
Reply By: Member - Phil G (SA) - Wednesday, Jul 18, 2007 at 19:11
I run the latest version of Ozi on W98SE.
Serial port is almost invariably COM 1.
In the Ozi configuration, you select the Garmin 76 under the GPS tab; and COM1 under the com port tab.
Only other thing is to have the GPS's interface set at none to NMEA for moving maps to work and chnage it to GRMN/GRMN if uploading or downloading tracks and waypoints.
AnswerID: 253218
Follow Up By: Member - Phil G (SA) - Wednesday, Jul 18, 2007 at 19:15
Whoops, forgot to add that the Baud rate is 9600 on upload/download and 4800 on NMEA.
FollowupID: 514318
Reply By: Member- Rox (WA) - Wednesday, Jul 18, 2007 at 19:36
Thanks for a quick reply will check it out tomorrow
Kev
AnswerID: 253225
Reply By: Richard Kovac - Wednesday, Jul 18, 2007 at 21:04
Hi Kev
Maybe try this addin Site Link
Richard
AnswerID: 253244
Follow Up By: Member- Rox (WA) - Wednesday, Jul 18, 2007 at 23:32
Thanks Richard, have got the info from this site. I checked it out on my gear & works great. I hope I have success tomorrow, when I get to TAFE & setup their gear. Thanks again Kevin
FollowupID: 514380
Reply By: Member- Rox (WA) - Thursday, Jul 19, 2007 at 20:55
Thanks all I have now fixed this problem
Garmin's have a box to tick "Use PVT for Garmin instead of NMEA"
This was ticked & I had to untick it for it to work.
I am not familiar as I use Magellan.
Thanks Again Kev
AnswerID: 253414
