EGT gauge fitted/TrackMaster roof rack Q?
Submitted: Wednesday, Jul 18, 2007 at 23:33
ThreadID: 47861 Views:3993 Replies:2 FollowUps:4
Hi All,
My EGT/pyro arrived today from thermoguard, and fitted it to the GU.
Great lil unit, very accurate, and easy to install, sweet fit.
Max EGT 538, so could give it more fuel, but i won't.
Everything else with the new turbo is brilliant.
The service from IAN at thermoguard was fantastic. Top quality gear and service.
I also fitted a TrackMaster roofrack today. Nice bit of gear.
Q: Does anyone know the roof load limit of the GU3??
Thanks guys
Wayne-o
Reply By: Trevor R (QLD) - Thursday, Jul 19, 2007 at 08:53
Sounds like you have it set just about right with those temps, when loaded and working hard it will climb a bit more than the the 538 you have seen. Mine will get up to 580 but that is when I start backing off to help cool things down. I have only ever got this hot when towing and climbing hard.
Roof load limit if same as GU1 is 200kg.
Cheers, Trevor.
AnswerID: 253308
Follow Up By: Wayne-o (Pilbara WA) - Thursday, Jul 19, 2007 at 11:40
thanks trev,
yeah, the truck is fantastic now. So much nicer to drive.
I have a no muffler pipe on its way from BD exhausts to replace the mufflered one, so should sound the part soon. The original BD one is a bit quiet.
Dont think id ever put 200kg on the roof but good to know.
Thanks pal
Wayne-o
FollowupID: 514420
Reply By: Ian from Thermoguard Instruments - Friday, Jul 20, 2007 at 09:20
Ta for the kind words, Wayne-o. (Where do I send the six-pack, then?)
Ian
AnswerID: 253500
Follow Up By: Member - Gomax (VIC) - Friday, Jul 20, 2007 at 20:26
Well Ian, I am so happy with my Thermoguard EGT and boost guages that a slab wouldn't go astray!Cheers Paul
FollowupID: 514671
Follow Up By: pt_nomad - Sunday, Aug 12, 2007 at 17:35
Wayne,
Is your sensor located pre or post turbo ?
Ta
Paul
FollowupID: 518071
Follow Up By: Ian from Thermoguard Instruments - Sunday, Aug 12, 2007 at 19:20
Hi pt_nomad,
As your post ended-up as a Follow-up to mine: I believe Wayne installed his sensor post-turbo. He has a Beaudesert Exhausts system with a 1/4" BSP fitting already in it and I'm pretty sure he used that.
FollowupID: 518092
