Tyre Flats / puncturing
Submitted: Thursday, Jul 19, 2007 at 07:43
Mobi Condo
Howdy all - an odd one to me as follows
Recently did an 11000 + trip
Adelaide to Kimberly via Tanami, GRR, then home via
Broome, Onlsow, Kalgoorly etc. Had four or five flats along the way - split rims, tubes etc and tyres at end of life so expected some trouble.
The puzzling thing is - in the last 9 years we would have dealt with 30 - 40 flats and ALL except one has been on the rear Off Side wheel!
Am I missing something here? It is NOT the same rim, tyre, tube, rust band combination as there is regular wheel rotation, tyres are old (at the end of life) at the time we start to have problems - but not damaged (we have had three to four tyre set replacements over the 9 years) All other
wheels have equal wear but the problems occur with this particular rear off side location!
Any clues????
Cheers - Mobi
Reply By: traveller2 - Thursday, Jul 19, 2007 at 08:10
I have had a similar experience due I suspect to a few reasons or combination thereof, 1/ that it is the LHS so therefore the road/track isn't watched as closely as the RHS in front of the driver, 2/ it is also the outer edge of the road where all the rubbish/rocks are flicked by passing traffic and 3/ the LHF flicks things up due to 1/ which are then run over by the LHR.
253299
Follow Up By: Member - Phil G (SA) - Thursday, Jul 19, 2007 at 08:26
And just to add, the rears usually carry more weight than the fronts
514399
Follow Up By: whyallacookie - Friday, Jul 20, 2007 at 14:29
(You might want to add on a trip carry more weight)
514602
Reply By: Robin Miller - Thursday, Jul 19, 2007 at 09:01
Hi Mobi
That is the worst spot all right , and we put best tyre in that spot.
Brother just returned from Lcool trip similar in length but via all desserts and Canning etc , they had new pro-comp muddies fitted for trip and lost 2 rears like that. Had to be replaced whilst on canning. Several others had similar tyre issues also, and they had fun and proved the Urban myth that tubless tyres can be reseated with propane (not reccomended).
Robin Miller
253310
Follow Up By: Des Lexic - Thursday, Jul 19, 2007 at 09:22
G'day Robin,
I've seen a video taken up in Greenland where a tyre was set on the rim and re-inflated using propane. Very spectacular and one day, I might give it a try with someone else's tyre/rim. LOL I've heard that a little shellite inside the casing with a trail to a safe distance also works. What would help the inflation in Greenland would be the very cold air and the tyres were only inflated to 4lbs anyway.
Mobi, most of the puncture causing objects are swept to the LHS of the road naturally and then the front tyre aligns them with the rear and bingo. Bugga!!!
514402
Reply By: Member - Fred L (NSW) - Thursday, Jul 19, 2007 at 11:03
Hi Moby,
According to the expert - Adam at the Pink House in
Oodnadatta - statistics show that the most likely tyre to puncture is the back left. I have just got back from a 9000 Km trip on mostly dirt roads and lucklily no punctures but have some rips in the back left tyre. I will need to do something soon with it I guess.
Fred
253323
Reply By: Member - peter C (WA) - Thursday, Jul 19, 2007 at 13:43
Not sure if anyone's complaining? Far as I'm concerned, if any tyre is going to go, that's the one I want it to be!
253335
Reply By: Motherhen - Thursday, Jul 19, 2007 at 13:58
Hi Mobi Condo
Come to think of it - it is the most common flat for us too. Some years ago, we toured around
Exmouth area and out to Mt Augustus (back in the days when you'd travel for days on station roads and not see another car). Back on the black heading towards
Geraldton the left back tyre blew out. We only had one spare, and when we put it on, it went down. I'd had it fixed just before we left (i think the lad took the easy path and fitted a tube), but he'd left the nail in it! When we got home, the
young man was no longer working for the tyre service - not surprising. We bought a new tyre in
Geraldton, and meet up with a friend, who'd had 3 blow outs within a few minutes when out in the station country - we were lucky as we were travelling with just the Ute and only one spare.
Even when the tyre peeled on the caravan last year, it was the left rear tyre. It didn't go flat though.
253339
Reply By: Mobi Condo - Thursday, Jul 19, 2007 at 14:20
Thanks all - interesting replies - I did mention rear OFFSIDE which I have always known as the right hand side (nearside being near the kerb, offside being the other side) so I really had the problem on the opposite side to all the responses.
Neighbour has just mentioned their son had an episode of this and it seems a
suspension problems was the cause??? Who knows???
Cheers - Mobi
253342
Follow Up By: Brew34.5(SA) - Thursday, Jul 19, 2007 at 15:57
Yep me too. Every flat i have ever had has been drivers side rear.
514439
Follow Up By: Member - John L G - Thursday, Jul 19, 2007 at 16:20
Drivers dietry habits perhaps????????? :-)
514447
Reply By: obee - Thursday, Jul 19, 2007 at 17:49
all the sharp things gravitate to edge of the road and the rear wheel is usually doing the work and not just rolling over things.
Owen
253370
Reply By: Member - Glenn D (NSW) - Friday, Jul 20, 2007 at 22:31
Hows it going Mobi,
Have only previously seen other people with tyre trouble. Also I have only run new or nearly new tyres ,
This happened on the rear passenger side , little warning but too late !
!MPG:6!
Glenn.
253644
