Overheating Diahatsu Rocky
Submitted: Thursday, Jul 19, 2007 at 08:29
ThreadID: 47867 Views:1962 Replies:4 FollowUps:0
Hi All
I have a friend with a 1983 petrol (2 litre toyota motor I believe) Diahatsu Rocky with overheating problems. The radiator , hoses and fan are all good.
A new thermostat was installed and overheating still occurred , however when the thermostat is removed it no longer overheats.
Both thermostats open when tested in a saucepan of hot water.
Any ideas of what else to look for ?
Darryl
Brisbane
Reply By: Member - Troll 81 (QLD) - Thursday, Jul 19, 2007 at 08:34
Maybe the radiator needs a professional clean and have you looked at the coolant?
AnswerID: 253303
Reply By: Member - Uncle (NSW) - Thursday, Jul 19, 2007 at 08:42
Maybe a stuffed water pump, or blown head gasket too? Welsh plugs ok? After a few years they can develop a small pinhole in them due to corrosion , heater core blocked? There's a vast number of reasons for it to over heat, but just try one by one I guess, process of elimination.Hope it works out. Unc
AnswerID: 253304
Reply By: madfisher - Thursday, Jul 19, 2007 at 13:49
Has the radiator been professionaly cleaned out? Also check hoses are not closing up. Your friend really needs a mechanic to look at it , could be cheaper in the end . If the motor is faulty brand new 4y motors in a crate are avaibable for about $1300.00.
Cheaper than reapairing a head problem
Cheers Pet
AnswerID: 253337
Reply By: Dazmit - Thursday, Jul 19, 2007 at 13:56
Thanks for the replies guys , I just checked again with him and it has new radiator hoses and water pump. Radiator has been flushed out but I don't believe the tanks have been off and rodded.
I was starting to wonder if the head is corroded blocking off some of the water galleries.
Darryl
Brisbane
AnswerID: 253338
